4180 Rebuild tips?
Old Sep 9, 2003 | 02:34 PM
rbrewrr's Avatar
rbrewrr
4180 Rebuild tips?
I'm planning on rebuilding my 4180 this weekend - any tips for a newbie?
Old Sep 9, 2003 | 02:37 PM
luckild's Avatar
luckild
4180 Rebuild tips?
GO slow, clean and clean,set specs to your application.good luck
Old Sep 9, 2003 | 10:21 PM
LxMan1's Avatar
LxMan1
4180 Rebuild tips?
Yes, Make sure that you get all of the old gasket material off, especially the metering block surfaces. Also, make sure to blow out all of the passages with carb cleaner or compressed air.
Also, go ahead and knock out the idle mixture screw plugs in the baseplate if it hasn't been done already.
Jimmy
