Check engine Light
Old Sep 8, 2003 | 01:24 PM
bentonsexpy's Avatar
bentonsexpy
Check engine Light
The check engine light came on the other day on my 97 XLT/5.4 and after a short review with other owners I replaced the DPFE sensor. That worked for about 100 miles then the check engine light came back on. I also noticed that it began to idle a little rough. Both Autozone and Advance auto parts check the diagnostics on the truck codes FREE. They stated that the codes were for the Oxygen sensors on the exhaust pipes. The one before and after the Cat converter. After $100 for these two babies I drove it a couple of miles and it still seems to have a little bit of a rough idle. But no check engine light yet.
Is there resources that show the identity of the computer codes?
Old Sep 8, 2003 | 11:34 PM
Ford_Six's Avatar
Ford_Six
Check engine Light
Welcome to FTE!
Have you tried disconnecting the battery? The computer may just need to be reset.
Old Sep 9, 2003 | 06:38 AM
bentonsexpy
Check engine Light
Yeah, I did that before I installed the Oxy sensors. Last night the check engine light came back on. So I'll run it back up and get it checked again. The thing is I want to know if there is some place to check what the code number's mean. The guy that read them just looked at the numbers and said "yep, it's the O2 sensor.
Old Sep 9, 2003 | 11:35 PM
Ford_Six's Avatar
Ford_Six
Check engine Light
Sometimes it is better to just spend the $65-$70 to have a shop diagnose it. At least that way, you have a better starting point. There are many different things that can affect the computer's reading of the O2s's. It could be from low or high fuel pressure, dirty injectors, a bad ground or connection somewhere, etc.
maxxf150
1997 - 2003 F150
Jan 1, 2010 11:05 AM
sethjamto
Sep 14, 2007 07:45 PM
Don D
1997 - 2003 F150
Jan 21, 2007 08:27 AM
Explorer98
Jun 27, 2006 09:28 AM
dtharrett
1997 - 2003 F150
Apr 29, 2004 11:57 AM
