4 link set up? Will it work?
Old Sep 27, 2017 | 08:07 PM
powerstrokemyd's Avatar
powerstrokemyd
Hey everyone! I'm looking into the heidts 4 link set up for my 1955 f100. I've seen a few forums where they used this set up with an 8.8 axle, but when I search the part number I need for direct fit, it says only for ford 8" and 9" housings. So will the 8.8 fit? Or will I need to modify the bracket system that holds the axle?
i would really like to use this axle where as it's totally rebuilt already and has the gear ratio im looking for.
Old Sep 27, 2017 | 09:09 PM
Gicknordon's Avatar
Gicknordon
If the axles tubes are different sizes you will have to account for that in the brackets. I think the pan hard rod is also designed to bolt to the front of the axle where the drop out center section is held on for an 8/9 inch ford, so you would need to figure out another way to attach it to the 8.8.
Old Sep 27, 2017 | 09:20 PM
powerstrokemyd
so i wonder if I'll need to make new ones or just modify the brackets that come with it. And I'll have to figure out the Pan hard rod. I've never done a 4 link before so this should be interesting. I can't seem to find another set up for the 8.8
Old Sep 27, 2017 | 09:59 PM
Gicknordon's Avatar
Gicknordon
I believe that paul horton welder series makes a few different kits for the 8.8, though they are universal so they might need just as much work as modifying the heidts kit.
Old Sep 28, 2017 | 12:04 PM
highdesert55's Avatar
highdesert55
i have the TCi four link, not sure how it differes from heidts but i had to open the mounts that weld to the axle tube a little to make them the right dianmeter for the 8.8 .
Old Sep 29, 2017 | 02:24 PM
Björn's Avatar
Björn
you need the weld the bracket on the axle
The bolt on bracket only work with the 8 or 9 inch axle
If you read it on their site the link to the bracket you need is in the text
Pearlwhite94
Sep 12, 2007 05:54 PM
eco
Oct 21, 2006 02:05 PM
todder53
Feb 16, 2003 04:05 PM
sternal2000
Oct 8, 2002 10:57 AM
