5th wheel hitch
Old Sep 27, 2017 | 04:37 PM
georefarl1945's Avatar
georefarl1945
5th wheel hitch
What Size 5th wheel hitch should I purchase for my 2017 F250 4x4 short bed. Reese with 13" to 17" or Curt 17" to 21" height. 2017 F250 XLT 6.5 bed 5x5.
Old Sep 27, 2017 | 07:53 PM
Tom N OH's Avatar
Tom N OH
Reese and Curt are both reputable brands, either one will work. Depending on the trailer, you're most likely going to want a sliding hitch so you don't blow the back window out of your cab.
Old Sep 27, 2017 | 08:13 PM
USSenator's Avatar
USSenator
Get an Andersen Ultimate aluminum. It will save 200+ lbs of payload.
Old Sep 27, 2017 | 08:21 PM
mwheue's Avatar
mwheue
If you are talking less expensive hitches I just changed from a Reese pro 15k to a Curt A16 because the Curt is a quieter hitch since it is double jaw vs slide bar. Mine is a long bed but the hitch is set at 17" and the pin box is set in the mid position on the trailer. I took the 3" rear blocks out and installed 1 3/4 in blocks from a 2016 and the trailer sits slightly nose high with the proper bed clearance.
Old Sep 27, 2017 | 08:53 PM
2009kr's Avatar
2009kr
If you're getting a traditional non-slider, I recommend the B&W companion. Very easy to hitch and unhitch.
Old Sep 27, 2017 | 09:03 PM
Brother_Bluto's Avatar
Brother_Bluto
I have an Andersen Ultimate Hitch in my GMC 2500HD SB and love it. It will be going into my 2017 F350 SB when it arrives as well. It does however require a gooseneck ball. If you want to stick with a traditional hitch, then make sure you also look at B&W as they are built like tanks, owners love them and I have never read anything bad on B&W hitches.
Old Sep 28, 2017 | 09:12 AM
Eric234's Avatar
Eric234
Another vote for Andersen ultimate fifth wheel hitch
hi
I previously had a shortbed truck and pulled a fifth wheel with the truck. I never had a sliding hitch and never hit my window. Most new trailers have extended pin boxes and cut outs on the front cap for shortbed trucks. I changed over to an andersen (approximately 8,000 miles towing so far and coast to coast) for 2 reasons: 1. The weight reduction vs a standard fifth wheel hitch. 2. The Andersen allows you to have approximately a 9" offset to the rear to further get away from you rear window.
Last thing: I have been at a campsite with a standard fifth wheel hitch that was unlevel, I hade to put blocks under one side of the truck to try and get it level so I could back hitch up to go home. Now I don't have that concern because I am going down in a ball.
good luck with your choice
eric
Old Sep 28, 2017 | 10:16 AM
Siriustoo's Avatar
Siriustoo
Every option will have its trade offs. I did a lot of research and ended up with a Demco Hijacker Autoslide 5th Wheel Hitch w/ Slider - Ford Super Duty Prep Package - 21K. Heavy but nice not to have to worry about problems with the 5th wheel making contact on tight turns and unlevel ground with my SWB. You may want to check with the frame manufacturer of your fifth wheel and try to get something in writing. I did and they told me that the warranty would not cover any type of goose neck setup, including the AUH. I went up the line a ways to make sure I had someone who knew what I was talking about. Of course if I asked the question ten times I would probably get 10 different answers. If you are thinking about the AUH you may want to check the forums about the use of safety chains... some states seem to require them, again your mileage may vary. The Demco is heavy and you can only be 10 degrees out of line to hitch. The AUH is definitely an interesting option.
Old Sep 28, 2017 | 10:30 AM
Tom N OH's Avatar
Tom N OH
I went with the Demco Autoslider too, love it, but it’s now for sale as I’m going to a long bed truck. No getting in & out of the truck to slide the hitch back, and then forward again. I can turn 90 degrees with no problem whatsoever. My concern with the AUH is that when you turn it around to move the hitch point rearward, you are taking weight off of the steering axle of the truck & adding it to the driving axle. I know Andersen says not, but it’s the simple principle of leverage. Elementary school stuff. You don’t have to be a mechanical engineer to figure that out.
Old Sep 28, 2017 | 11:19 AM
First Dually's Avatar
First Dually
The pivot point being located towards the rear with the AUH sure could help with clearing the cab of a short box when turning. But I'm not so sure I like placing the load further towards the rear of the truck. And apparently, turning the pyramid so the pivot is further forward is a no-go unless using the rail mount AUH. Why not with the non-rail mount?
As for trailer frames not being warranted when using a goose neck hitch, I suspect it's not exactly that cut and dry. (Although the hassle and legal costs could make the battle seriously painful.) My guess is the frame manufacturer would have to prove the damaged was actually caused by the goose neck adaptor. The lever arm created by some goose neck adaptors could easily fall into that category. The AUH, not so much.
Old Sep 28, 2017 | 11:20 AM
First Dually
Old Sep 28, 2017 | 12:02 PM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
My truck came without the factory prep package so I went old school. Went with the Curt Q20 and it's been great so far.
Old Sep 28, 2017 | 12:04 PM
Siriustoo's Avatar
Siriustoo
I was concerned about weight distribution as well. That and what would happen if you rear end someone. What is the lateral shear force and can the AUH withstand it.
Old Sep 30, 2017 | 09:49 AM
Krazyhorse's Avatar
Krazyhorse
I had a b&w companion for 8 years or so, and it was a great hitch. Went with a Curt Q25 for the new truck and am very happy with it. Even happier with the price vs. the B&W.
Old Sep 30, 2017 | 06:52 PM
Curtis Lipinski's Avatar
Curtis Lipinski
I have the Andersen also. Love it at 30 pounds.
