what could be wrong with my 2006 ranger
Old 09-27-2017, 12:13 AM
SeaBananaGames1's Avatar
SeaBananaGames1
SeaBananaGames1 is offline
i have a 2.3 L 4 cylinder ranger that recently started having battery problems(well at this point i don't know if it's a battery problem...) couple days ago it wouldn't start, i jump started it and it ran and was perfectly fine for a couple more days until today. wouldn't start- i jump started, drove for maybe 5 feet and it turned off on me again. realized that it only stays on if you rev hard, so i took it home (revving the **** out of it) cause i was close to home and our battery charger thing says it's fully charged and fine but i'm not sure what's up with it. oh also in park i revved it hard and it only limits up to 3k rpms
help and thank you!
Old 11-03-2017, 12:38 PM
5_labsownus's Avatar
5_labsownus
5_labsownus is offline
Received 1,563 Likes on 1,456 Posts
The symptom you described is common to an Idle Air Control (IAC) valve. I have seen them produce a DTC code but many time they did not. As for for the battery issue, I would take to one of the parts stores and have it tested. They will do it for free and are pretty accurate.
Rod
Old 12-16-2017, 10:21 AM
RangerRuss's Avatar
RangerRuss
RangerRuss is offline
Look for a vacuum leak. There are videos on different ways to do this test.
MasonRoberson
General Automotive Discussion
08-24-2016 07:04 AM
JakeAnderson329
1983 - 2012 Ranger & B-Series
02-12-2014 03:10 PM
sbjess03
10-26-2010 02:07 PM
drb1956
01-16-2009 10:34 AM
OddManOut
02-14-2006 10:17 PM
Quick Reply: what could be wrong with my 2006 ranger
