V10 interchange
Old Sep 26, 2017 | 09:52 AM
50_chevy's Avatar
50_chevy
V10 interchange
I’m researching to buy an excursion so I appreciate the any info you can give.
I’ve run across quite a few threads saying that the v10 really didn’t change
through the production of the excursion . The main change I can figure from
Reading is to the heads to deepen the threads for the spark plugs to avoid the. bottle rocket issue ( 03 if I recall )and going to 3v heads ( don’t recall when that changed ).
The question I have is when I was researching maintenance items and on the extreme end the cost of actual engine replacement . I found that the parts interchange for the v10 falls as 00-01 and then 02-05 . I was wondering if anyone knows why the interchange is broken up like that. Is it a wiring harness / Ecu change due to the change in heads ?
If the interchange is 2002 - 2005 does that mean I should dismiss the 00-01
Models because of the change / update ?
Thanks again
Old Sep 26, 2017 | 10:13 AM
thor363's Avatar
thor363
No 3 valve heads were ever used in the Ex.
Old Sep 26, 2017 | 10:18 AM
50_chevy's Avatar
50_chevy
oh maybe I misunderstood and it was a general V10 change from 2v to 3v .
Old Sep 26, 2017 | 10:39 AM
WE3ZS's Avatar
WE3ZS
As Thor said, the EX only ever got the 2V heads, even in '05 when the rest of the SD trucks got the 3V V-10 and 5 speed trans.
The V-10 interchange runs all the way up to the last year for the full sized Econoline vans, they also kept the 2V motors up till the end. They do use a different oil pan though, so that would need to be changed for an EX installation. If shopping for a used/rebuilt 6.8 I would make sure it had the '03+ heads with the increase number of spark plug threads. The van motors are still available brand new from ford and of course are the better heads.
Old Sep 26, 2017 | 12:39 PM
50_chevy's Avatar
50_chevy
if I end up with a really great 01 can the later 03+ heads be swapped onto it ?
Old Sep 26, 2017 | 12:54 PM
WE3ZS's Avatar
WE3ZS
Yes, as long as they are the 2V heads.
Old Sep 26, 2017 | 03:35 PM
50_chevy's Avatar
50_chevy
well thats kinda nice - is there an I identifying casting for the updated 2v heads ?
if I replace the heads that should fix the bulk of the common 01 engine issues , correct ?
Old Sep 26, 2017 | 04:34 PM
WE3ZS's Avatar
WE3ZS
Just count the threads for the spark plugs, if that is what you are looking for.
There really aren't a "bulk" of motor issues with these 6.8s, the early ones with too few plug threads can be fine if you overtorque the plugs and recheck them after a few thousand miles. Otherwise broken exhaust manifold studs are a common issue across all of the modular engines and those can be a pain but are doable, I did mine in the driveway.
Old Sep 26, 2017 | 07:07 PM
rock2610d's Avatar
rock2610d
2000 and 2001 V10s have lower compression than 2002s and up. It's a piston dish size change and not the heads.
I believe all V10 2V motors from 2002 to the 2014 ones in E350 vans are the same. Except the E350 CNG motors that have hardend valve seats in heads.
imabass
Modular V10 (6.8l)
May 24, 2017 04:32 PM
smallmunster
Jan 3, 2017 09:12 AM
Green_Monster
Modular V10 (6.8l)
Mar 17, 2008 10:14 PM
jhemr
Modular V10 (6.8l)
Jun 22, 2004 05:22 AM
nothingbutford
Aug 27, 2001 11:52 AM
