Sponsored by: Real Truck
Oil change interval
Old Oct 2, 2017 | 01:50 PM
  #31
The Bone's Avatar
The Bone
If you dont drive your truck that much than once a year is good, less than 5,000 miles. I always use synthetic because its good for seals and gaskets.It is best to get them out once a month to keep the oil circulated in the motor. As for filling the filter with oil good idea if the filter is up and down. I had a car that the filter was sideways so I couldnt do that. Follow the computer and you will be fine otherwise you are just wasting money and oil. Up to each individual. I have a great relationship with a Ford parts guy and he gives me a deal on oil. Then I go to the Quick Lane guy and tell him I got the oil in the truck so it only cost me $25 for the change and about $130 for the oil.
Old Oct 2, 2017 | 01:56 PM
  #32
seville009's Avatar
seville009
You’re supposed to change the oil........?
Old Oct 2, 2017 | 05:29 PM
  #33
Chuck-B's Avatar
Chuck-B
6.7 Weight Loss
Bryan, I'm with you man - may not change my brake fluid once a year but I certainly do change my oil more frequently - 5,000 miles - the purpose of the oil analysis isn't to increase my change interval, it's to see if there is anything bad turning up in the oil as an indication of something going wrong. And I do fill the filter with oil to reduce the amount of time the engine is running without oil. Not to mention I recently added an Insane Diesel oil bypass filter - and I'm still going to change the oil every 5,000 miles
Old Jan 19, 2018 | 07:23 PM
  #34
Fefanatic's Avatar
Fefanatic
Originally Posted by dirthawg
Anyone have any hard scientific facts as proof to back up the claims that oil sitting in an oil pan with little to no use will deteriorate or draw moisture that could cause rust or engine damage?
I have a portable Honda Generator sitting in an unheated/cooled garage which can fluctuate between 110F with high humidity to 20F depending on the season, that has Mobil 1 10w30 synthetic oil in the crankcase. Last time I changed that oil was 2006. I start the generator once or twice a year just to make sure it starts and runs, drain the fuel every couple of years (I use only non-ethanol fuel) and that's it. Summer of 2016 our power went out and I ran that generator for 30hrs straight without shutting it down. If moisture was a concern that engine would of locked up after 30hrs of constant 3600rpm.
The moisture claim has got me curious. I might go pull the pan on the spare 16hp Kohler mower engine I have sitting in the shed that hasn't ran a drop of fuel in 10+ years that has a new oil and filter which I installed before placing it on the shelf. I live in a high humidity climate so if moisture is an issue I should see it.
I understand these are not automobile engines but machined steel is machined steel, and bearings are bearings, only difference would be they are smaller.
If it's setting for extended lengths of time the particles (dirt/sludge) will eventually settle in the bottom of the oil pan. Once you start it after setting the first thing picked up by the oil pump is all that foreign debris. (FOD). It depends on what you consider a long time setting.
FWIW, I bought a old Chrysler that had been setting for a couple of years. When I drained the oil you could see a dark strip in the oil that came from the bottom. I dropped the pan to find about 1/4 inch or so of loose dirt. That would have been picked up in the oil pump immediately upon start up. I'm not sure the oil filter would have trapped it enough to avoid damage to the engine. FWIW.
Old Jan 19, 2018 | 10:20 PM
  #35
speakerfritz's Avatar
speakerfritz
I have personally observed condensation as a result of differences in day and night temps .
Old Jan 20, 2018 | 06:04 AM
  #36
Bugzilla46310's Avatar
Bugzilla46310
Originally Posted by texastech_diesel
Anyone want to argue about tire rotation intervals next?
I rotate my tires every 10 k, when I change my oil!
Old Jan 20, 2018 | 09:44 AM
  #37
texastech_diesel's Avatar
texastech_diesel
Token Redneck
Don't you know that's WRONG because (non-technical argument)! Your (insert part related to [tires]) will fail earlier now and you'll be out (outrageous dollar amount) because of your ineptness and lack of consideration for my (expert credential) and (personal experiences).
Please avail yourself of my internet forum knowledge, concede your ignorance, and rep me to show all the other schleps here that I am an Internet Forum Wizard of Great Repute
Old Jan 20, 2018 | 11:12 AM
  #38
F350 1990's Avatar
F350 1990
Chucky says you can listen to grandma, Uncle Bubba, etc about changing air in tires, but it's better to simply follow the OEM's oil change schedule.
Old Jan 20, 2018 | 02:03 PM
  #39
speakerfritz
Changing air....no....use nitrogen....or not.Air molocules will escape and contract during cold and leave behind moisture.Nitrogen has bigger molocues so it’s harder to escape. Confusing.... Air is 80% nitrogenSo if the non big roger molocues escape...refil with air...then more non nitrogen molocues escape....refill again...and eventually you will have pure nitrogen anyway.So refill with air. Save your nitrogen money for oil.
Old Jan 21, 2018 | 03:33 AM
  #40
George141's Avatar
George141
..plow truck once a year, add I liter halfway trough no dip stick (dip stick housing rusted off), my 08 diesel 6.4 once a year...runs like a champ (about 5k annually)...use a good quality oil and filter. As long as you go easy on the truck you should be ok.
Old Jan 21, 2018 | 07:21 PM
  #41
geekwithoutacause's Avatar
geekwithoutacause
It's hogwash. Oil sitting still not in any direct weather is fine for many years. The worst part is when you park it long term and there is moisture in there from not fully warming up. Only park it long term after a nice long trip where the oil got up to temperature and had a chance to get rid of any moisture. Once it parked, do not start it once in a while since this will introduce condensation. Keep the battery on a charger and you're all good. I am in same situation and still change it once a year since the manual says so. I doubt that's even needed but...
MPNX2
Aug 26, 2018 12:43 PM
SHOpar
6.7L Power Stroke Diesel
28
Nov 14, 2015 12:07 PM
KPT
Jun 13, 2013 07:27 AM
Boomer23059
64
May 15, 2012 10:43 AM
gregarobinson
2004 - 2008 F150
32
Dec 15, 2004 03:06 PM
