Feeling the Bumps
Old Oct 7, 2017 | 09:54 AM
A&Pmech's Avatar
A&Pmech
This is my first solid front axle vehicle in 20 years, so I'm not very experienced with the characteristics. I've noticed mine willl go just a little off course when going over a bump at higher speeds, I always figured this was do to a combination of the stiffer suspension and the solid front axle.
Old Oct 7, 2017 | 11:51 AM
Iowa Boy's Avatar
Iowa Boy
Yup, they do bounce and veer off course. i have lowered my front pressure to 60 pounds and i may have to go down to 50. I just don't want the tires too low so they start to increase rolling resistance or flex to much.
Old Nov 14, 2017 | 11:22 AM
Iowa Boy's Avatar
Iowa Boy
Well I finally took the truck to the dealer to have it checked out. I told them I hate how it drives due to all the bump steer. They took it for a drive and said that they didn't see any issues. Then I took a drive in it with the service manager to show him what its talking about and he says that is just the way the super duties drive. He said at least you don't have the death wobble yet. I had them put it on the rack and check the alignment and it was all with in spec. I can't believe that there are not more posts about how poorly there trucks drive. I guess I will try an aftermarket steering stabilizer once they are available. I would like a dual stabilizer but i don't want to lift the front of the truck as it barely fits in the garage the way it is. Well, i just thought I would post what I found out about my truck. I guess I will either have to accept the poor steering or trade it off. Time will tell.
Old Nov 14, 2017 | 11:58 AM
Paw's 150 Lariat's Avatar
Paw's 150 Lariat
I actually thought the ride in my DRW would be worse then what it is. I find it to ride better then the 2000 F-250 I had years ago with the camper package. It was a Supercab with the shortbed and it rode like a brickwagon. Other then the ride it was the most trouble free vehicle I've ever owned. My '17 with the 176" WB rides as smooth as the '13 F-150 I had that had the factory 20" wheels.
Old Nov 14, 2017 | 12:14 PM
rfbrain's Avatar
rfbrain
I'm not sure if what is being described is actually "Bump Steer". In a solid front axle vehicle as long as the Track Bar and Drag Link are in parallel with each other there should be no Bump Steer as the suspension articulates. Bump Steer is usually much more common in double wishbone/independent front suspensions such as the F150 and GMs.
Old Nov 14, 2017 | 12:22 PM
Iowa Boy's Avatar
Iowa Boy
Well, call it what you like but any bump rocks the steering wheel. I did a search on here and it seems to be a common problem. Maybe Ford should worry a little less about all the fancy electronic bells and whistles and focus on making the best driving truck on the market. I'm surprised that they are not constantly in class action lawsuits over how poorly these trucks drive. Just my opinion.
Old Nov 14, 2017 | 12:55 PM
AK_SuperDuty's Avatar
AK_SuperDuty
My F350 is totally smooth over bumps. I had major issues with bad steering wheel vibration at various speeds due to a bad set of tires, but with the Toyo Open Country AT2's I had installed, the truck performs better than any other vehicle I've driven. I think yours has a problem. It's not an engineering issue unless a large number of them have the same problem.
Old Nov 14, 2017 | 02:26 PM
mmuglia's Avatar
mmuglia
I was experiencing the same type of issue when hitting bumps and the truck didn't seem to track straight on the expressway. I brought it to the dealer and had the alignment checked and they said everything was in spec. Knowing this all seemed like an alignment issue, I brought the truck to the shop that aligned my F150 after I leveled it and had them check the alignment on my 3-day old F250. The passenger front tire was at .25 degrees negative toe and the driver front was .25 degrees positive toe. I asked the mechanic to leave the passenger side alone and set the driver side to .25 negative. All problems solved. No more jerking wheel when hitting bumps and the truck tracks perfect on the expressway.
Jmiller80
Apr 24, 2019 08:02 AM
swaman
Garage & Workshop
Aug 23, 2014 11:45 AM
VIPERK30
Apr 15, 2011 12:35 AM
stewards68
Jun 21, 2007 09:59 PM
saville
Feb 25, 2007 09:34 AM
