Using the manual shift vs. automatic
Old Sep 25, 2017 | 02:13 PM
dkolt's Avatar
dkolt
I have a F250 with a fifth wheel.. a friend has told me i should use the Manual shift instead of just dropping it in drive and pulling the 5th wheel.... better gas mileage and better for transmission ...
Old Sep 25, 2017 | 02:51 PM
RV_Tech's Avatar
RV_Tech
I doubt the transmission cares and mileage may be a crap shoot, but I use manual when out West with serious grades. I think it makes the truck perform more the way I want it to then allowing the transmission to choose. Back home in the Southeast, I just lock out 6th and go. There just are not enough serious grades to give it a second thought.
I would opine that where one travels plays a major role in driving preferences.
Steve
Old Sep 25, 2017 | 04:06 PM
Chuck's First Ford's Avatar
Chuck's First Ford
use manual or use full automatic..
except for long down hills... use full automatic. just lock out 6th gear.
computer controlled transmission.. it will take care of it's self.
Old Sep 25, 2017 | 07:49 PM
scraprat's Avatar
scraprat
Top Answer: 5
Is this gas truck or diesel?
Old Sep 25, 2017 | 08:02 PM
HRTKD's Avatar
HRTKD
Like Steve said in post #2, I only use Manual mode when descending mountain passes. Otherwise, I leave in D and let the transmission do its thing. I do enable tow/haul mode, but only when I have my RV trailer behind me. The ATV trailer is light enough that it tow/haul isn't needed.
Old Sep 25, 2017 | 08:52 PM
Tomc750's Avatar
Tomc750
As I was traversing a steep grade and down another today, I was experimenting a bit on the best way to control the speed of the rig. I had done this grade with the same partially loaded trailer several days in a row, trying tow haul, exhaust brake, manually selecting gears, etc. I commented to my wife who was riding with me that it was so much easier to drive a manual transmission, so much more intuitive, and satisfying as well.
Old Sep 25, 2017 | 09:41 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
It's not better for the transmission. On the other hand, it's not worse for the transmission, either. The transmission was engineered to be durable in either mode.
If you really understand the engine BSFC (Brake Specific Fuel Consumption) charts then you MIGHT be able to squeak out a couple tenths of MPG out of manual mode. But that was considered when creating the automatic shift schedules, so there really isn't much to be gained.
Do you want to know what BSFC is? https://en.wikipedia.org/wiki/Brake_...el_consumption
Old Sep 26, 2017 | 05:36 AM
senix's Avatar
senix
I use automatic and cruise control in tow/haul mode as a general rule.
On steep descents then I switch to manual to better control the downhill run.
Old Sep 26, 2017 | 06:58 AM
'65Ford's Avatar
'65Ford
Pretty much agree with everything said already. IMO, there are more benefits to today's auto besides giving your left leg a rest. They're formulated to keep your truck in the "sweet spot" for power and efficiency. They protect your engine from being excessively lugged and over revved. So unless you're in a peculiar scenario or headed down some steep hills, just stick it in D along with tow/haul when towing. I click on the cruise too on the interstates.
Used to be manuals got better fuel economy with a prudent driver...not so sure anymore. Today's autos are pretty good.
Old Sep 26, 2017 | 10:55 AM
-brent's Avatar
-brent
It is mostly what we are comfortable with. I live out West, and use manual shift with the 5th behind me on/in the hills. On the flat I just lock out OD-- however, I continue to lock out gears when braking just because I can.
With my diesels, it was a different story.
Old Sep 26, 2017 | 11:02 AM
RV_Tech's Avatar
RV_Tech
I do the same when the fiver is hitching a ride.
Steve
Old Sep 26, 2017 | 12:43 PM
69cj's Avatar
69cj
When descending I just let the CC and engine brake do their things. I just keep her between the lines.
Old Sep 26, 2017 | 03:52 PM
BCooke's Avatar
BCooke
I use manual when I want to force it to downshift.
Upshift, I back off enough so it upshifts and then depress the foot. (to keep it in the power/torque sweet spot)
Old Sep 27, 2017 | 08:56 PM
skyking897's Avatar
skyking897
Steve
I've seen this quoted several times now, how do you lock out 6th gear?
Old Sep 27, 2017 | 09:12 PM
RV_Tech's Avatar
RV_Tech
It's in the owners manual. When you are running in "D" on the shifter just press "-" and you will see 6 vanish from the selector. You can go the same to lock out any gear to avail constant shifting in hills or when pulling a load. You can bring them back by hitting "+". When you turn the engine off, it all resets. Your transmission still shifts automatically, but you limit the number of gears it can choose.
If I have to lock out more than 6th, I am likely to move the selector to "M" and just shift manually.
Steve
