Timing/Spout Connector Issue 88 F250 460 EFI
#76
#77
A normal cold engine start-up is about 16-1800 rpm for 30 seconds, then a drop to 1000-1200 for another 30 seconds, then a gradual decrease to proper Idle rpm. Is this what you have ?[/QUOTE]
Yes that sounds about right for the cold engine start-up rpm sequence. It just seemed to idle sort of erratically once it warmed up, but that was only with the timing set to 10 degrees and the spout plugged in.
Sensors that affect timing;
PIP, O2, ECT, ACT, BP, EVP, TPS, KS[/QUOTE]
Do you mind spelling these out for me please?
PIP - ?
O2 - Oxygen sensor (HEGO)
ECT - Engine Coolant Temp
ACT - ?
BP - Back pressure or Barometric pressure?
EVP - ?
TPS - Throttle Position Sensor
KS - Knock sensor
#79
“Profile Ignition Pick-up (PIP) signal, which is used by the EECM and TFI to provide base timing information, determine engine speed (rpm) and crankshaft position.”
ACT – Air Charge Temperature sensor – in the intake manifold measuring intake air temperature.
BP - Barometric pressure
EGR Valve Position (EVP) Sensor – sits on top of your EGR Valve
#80
I don't know, I found this years ago. I use it to re-set Idle after the Throttle Butterfly Valve adjustment screw has been tampered with.
More of a fine tuning adjustment after everything else is fixed, and the idle still has issues.
#81
#82
[QUOTE=mrjustice1324;17521413]
Yes, one of those, there are about 6 of them, you will have to find the right one.
Ok, great identifying the signal wire.
Your Drawing in Post #56, shows that the GY/Y is connected to Fuse Link (W) most likely up by your Starter Solenoid connections. You will need to check if the Fuse Link is blown, or if it is still connected.
There may be other electronics feeding off of Fuse Link (W) as well.
QUOTE]
QUOTE]
#83
[QUOTE=vjsimone;17521711]I'm assuming I can test those by checking voltage on both sides to see if its sending power? I didn't see anyway to open it up to check a fuse. Unless by fusable link it just means that it connects one wire to three
#84
I will double check my lines the best I can, can't you use starting fluid by spraying around the lines and seeing if the rpms increase?
#85
#86
Did you leave the vacuum line attached ? If not you may get a Code 33, but nothing to worry about, just a code you live with, capping off the EGR.
#87
[QUOTE=mrjustice1324;17521724]
Yeah, just got to probe the wire on each side of the F-Link. sometimes the F-Link includes the entire Link wire, (14 Gauge), it could burn out anywhere along the link.
Yes, some F-Links connect to multiple wires, and those connections are just buried under some tape down the harness in places you would not expect.
#89
[QUOTE=vjsimone;17522011]
Well I traced what I thought to be the correct GY/Y wire yesterday all the way to under the steering column only to find out that it ran to the clutch and fuse panel...im assuming that wasn't the right GY/Y wire it got dark so I couldn't start my tracing over but I'll hopefully get a chance this weekend. Do you have any idea of where I should be looking for this specific F-link? The one in the picture went to the alternator and the only other ones I've found were under the steering column and didn't not connect to the GY/Y wire. I assumed the wire would go to the ignition since it is only on in the RUN position
