Cutting Off Drip Rails
Old Sep 24, 2017 | 04:48 PM
NS70250's Avatar
NS70250
I don't want to, but I have to. Does anybody have any advice? Mine are very rotten and there is not much to save in some sections.
It seems that it would not be too hard to cut them flush, but I'm not sure how to deal with the +/- inch (no the lip/channel part) that sits flush along the inside of the door frame area.
At first I thought I was going to be able to save them, but they're too far gone. I've seen trucks that have had it done so any advice would be appreciated.
Old Sep 24, 2017 | 08:40 PM
TeachNlive4ever's Avatar
TeachNlive4ever
Some one can n here has done or is process of it. As. Recall, there are two sheets on metal that are rolled to create the gutter. My suggestion would be to do sections at a time and tack weld as you go.
Old Sep 25, 2017 | 01:32 AM
HIO Silver's Avatar
HIO Silver
IIRC, there are three layers... the inner and outer, and the driprail is a separate piece that is sandwiched between.
The crew at Martin Bros. Customs (on Velocity Channel's "Iron Resurrection) shaved the rails on a C10 but added a narrow strip to create a very small flare which still shed/drip water beyond the window frame gap.
Old Sep 25, 2017 | 03:02 AM
GaryKip's Avatar
GaryKip
Didn't Randle cut off the drip rails on his white truck?
Old Sep 25, 2017 | 08:25 AM
orich's Avatar
orich
I've seen many dents in the junk yard with the windshield gasket lip all rusted out due to the gasket leaking. So if you do shave off the drip rail make sure your w-shield gasket don't leak. Or just keep it out of the rain an car wash that could let water get under the seals lip.
Orich
popeye69
Paint & Bodywork
28
Dec 30, 2020 06:58 PM
2pfspiff
Sep 15, 2007 12:13 PM
kld1958
Jul 20, 2007 08:59 AM
lgtwood
Paint & Bodywork
Sep 29, 2006 06:23 AM
OilLeaks
Sep 6, 2006 02:04 PM
