12VDC power tap from bed light switch?
Old Sep 24, 2017 | 04:42 PM
halifax's Avatar
halifax
Hi Friends,
I have a 2017 F350 Lariat and I need to run 12VDC in the bed area where my dogs travel crated under a cap. Can I safely tap the 12VDC switch for the OEM bed lights to get a always-hot 12VDC connection?
Thanks for your help.
Old Sep 24, 2017 | 04:46 PM
wb6anp's Avatar
wb6anp
No, the light switch for the bed lights is actually low power I believe 5 volts for the led's, My topper installer wanted to tap those wires for the led in the shell they had to run a wire all the way to the battery. You can use a volt meter to check but I believe all the trucks are the same.
Old Sep 25, 2017 | 05:12 PM
Herb Brooks's Avatar
Herb Brooks
How about the battery charge wire in the trailer plug?
Old Sep 25, 2017 | 05:17 PM
brickman's Avatar
brickman
Might that show up up on dash as trailer connected?
Old Sep 25, 2017 | 05:46 PM
Herb Brooks
I think that signal is from detecting trailer brakes. Separate wire.
Old Sep 25, 2017 | 05:47 PM
Herb Brooks
OP do you have up fitter switches?
Old Sep 25, 2017 | 06:03 PM
halifax's Avatar
halifax
Thanks for the replies.
Yes, I do have the upfitter switches. Pick off one from the bundle and run it back to the bed?
Thanks again.
Old Sep 26, 2017 | 12:28 AM
MagicMtnDan's Avatar
MagicMtnDan
Here's what I posted on the Ford Raptor Forum...
I am looking at running wires from the Battery and Upfitter AUX location to the rear bumper (for lights I installed under the bumper) in the engine compartment inside Liquid Tight flexible conduit (1/2") secured to/above the frame rails to keep them up out of the way.
If I do this I'll likely branch a line off and run it up inside the Bed as I want to install a power panel (a plastic box with outlets, etc. installed in the cover) with a Blue Sea Systems power distribution block along with a couple of 12v outlets, a dual USB charger outlet, a 12v digital volt meter, and a switch or two.
Liquid Tight flexible conduit example:
Conduit connectors - screws into Liquid Tight and the threaded end would be secured to a plastic box:
Junction Box - I'll use the cover for the 12v and USB outlets and the switches:
Digital Volt meter:
Lots of panel mount products here: https://powerwerx.com/panel-mounts
Inside will be the wiring and the Blue Sea Systems panel:
https://www.graybar.com/store/en/gb/...c-junction-box
I'll likely use this type of Blue Sea Systems Fuse Block (probably this 6 circuit unit) which I'll put inside the plastic box:
I'll have to run a hot and ground to it as it has a negative bus.
The cover of the box will kind of look like this (but I won't use Powerwerx's black panel - I'll just drill the holes in the plastic box's cover:
I've done this before on my Jeep and really liked it a lot.
Powerwerx has numerous electrical products (as shown above) and they also sell the Blue Sea Systems line of products - a great product line. And they're local here in SoCal: https://powerwerx.com/dc-power-products
I'm also looking at if I need a switch panel to control anything in the bed remotely. I don't think so but I can either make my own or buy one. I do like the bluetooth enabled switch panels as you can control your accessories with your smart phone.
Old Sep 26, 2017 | 01:28 AM
sigfla's Avatar
sigfla
Use this. Ruff Tough Kennel Fan Round 7 Pin Power Cord with 4 Pin Trailer Connector. $24.99.
Old Sep 26, 2017 | 07:36 AM
shortride's Avatar
shortride
This is what I would do as well. That's what the Upfitter switches are for.
Old Sep 26, 2017 | 07:41 AM
halifax's Avatar
halifax
(snip...)
Thanks for this post. I was wondering about how to protect the wires running back to the bed. This sounds like a right and proper solution.
Where do you run the wires into the bed?
halifax's Avatar
halifax
Wondering if the trailer connector is hot or does it require a connection to the trailer wiring to go hot?
Old Sep 27, 2017 | 04:32 PM
rather_large_250's Avatar
rather_large_250
I just did this very thing in my rig!
Old Sep 28, 2017 | 09:08 AM
cnm_mike's Avatar
cnm_mike
This is what I use when I need 12V in the truck bed.
Amazon Amazon
Mike
Old Sep 28, 2017 | 09:28 AM
xxxsherpa's Avatar
xxxsherpa
Outstanding job Large !!!
