Dually E-350 - where to find?
Old Sep 23, 2017 | 12:01 PM
RenoHuskerDu's Avatar
RenoHuskerDu
I just test drove a dually here in Austin that came from Georgia and it's rusted up pretty bad, the front doors are breaking at the seams of the forward Edge. Lots of other mechanical issues too. I'm wondering, where would a fella look if he wanted to find a 350 dually in good shape?
Old Sep 23, 2017 | 03:13 PM
vettex2's Avatar
vettex2
Dually van?
You make one
Old Sep 23, 2017 | 04:14 PM
RenoHuskerDu
This one has big issues. Converted in San Antonio, then worked in Georgia.
https://austin.craigslist.org/cto/d/...288321643.html
Old Sep 23, 2017 | 07:05 PM
lhoward1134's Avatar
lhoward1134
Ditto on making your own. You can be way more selective with the vehicle.
Old Sep 23, 2017 | 07:36 PM
wiskeyVI's Avatar
wiskeyVI
I keep thinking about building one myself, but just realized, looking at that add, you can't open the double door all the way.
Old Sep 23, 2017 | 11:41 PM
RenoHuskerDu
Could I source an F-350 drw for parts? Would that get me all needed parts including master cylinder, hubs, axles, fender flares? Does the steering box need to be changed? Probably would need a custom driveshaft.
I see more 6.0 Powerstroke motors than 7.3s for sale. Bullet proofing a 6.0 with limited clearance might suck. Body off required?
Lots to think about... Maybe you can drop a clean E body onto an F-350 drw and get the same results easier.
Old Sep 23, 2017 | 11:56 PM
lhoward1134
I can't tell you absolutely on any of that, but from my snooping around, I would say probably not. The frames are different, the axles are different. As for just the vans, I'm not sure about the rear, but I'm pretty sure on the front you just need the drw rotor and hub setup. The box van we had looked exactly the same as the 15 passenger we have now except the hub is spaced out off the rotor for the drw set. I'm sure someone else will respond with some good information. You can see them here.
https://www.rockauto.com/en/catalog/ford,2006,e-350,5.4l+v8,1432379,brake+&+wheel+hub,rotor,1896
One last thing is that if I were pulling a heavy trailer much, I'd probably go with the shorter (12 passenger) body. The rear overhang on the extended body is quite far.
Old Sep 24, 2017 | 01:58 PM
vettex2's Avatar
vettex2
nope, try googling Ford van dually conversion
Old Sep 24, 2017 | 10:36 PM
RenoHuskerDu
This is nuts. Prosemidually has a kit to do the job. But it's just wheels and fender flares.
http://prosemiduallyconversiontruck....5-passenger-2/
I asked them for more info. No hubs? Springs? Brakes?
Old Sep 25, 2017 | 07:35 PM
Slowped's Avatar
Slowped
4wd Low
This website has a list of companies that convert to dual wheels on Ford van; scroll down for it.
https://vanangels.wordpress.com/dual-wheels/
Here is another site with a kit: http://duallyfendersfiberglasstruck....onversion.html
Old Sep 25, 2017 | 10:31 PM
RenoHuskerDu
Thank you. I found the video
that shows dually van doesn't roll, srw van does.
vettex2
36
May 8, 2020 01:10 PM
RenoHuskerDu
18
Apr 30, 2019 01:50 PM
MiniVanMadMan
Aftermarket Products
Feb 27, 2018 10:38 PM
jason webber
Aug 14, 2016 09:05 AM
