Upfitter switches
Old Sep 20, 2017 | 08:54 PM
wb6anp's Avatar
wb6anp
Upfitter switches
To start off I know switch #'s 5 and 6 can be set to hot at all times, not through the key. What I want to know is there anyone that has ever figured out how to make any of the other switches hot at all times? I want to wire my dash cam to one but it doesn't need a 40 amp circuit. I want to be able to switch it off when at home, but leave it running so it goes to parking mode when I am out.
Old Sep 21, 2017 | 02:05 AM
MagicMtnDan's Avatar
MagicMtnDan
How can Upfitter Switches 5 & 6 be set to hot all the time - using FORScan?
Old Sep 21, 2017 | 05:25 AM
rwilimo's Avatar
rwilimo
I believe this would take a little rewiring inside of the upfitter fuse box, you could certainly replace the fuse with a smaller one if that's what bothers you unless you have another need for that circuit.
Old Sep 21, 2017 | 05:26 AM
rwilimo's Avatar
rwilimo
I believe the fuses for those circuits have 3 terminals in the block, by moving the fuses over it then gives you hot all the time circuits
Old Sep 21, 2017 | 07:21 AM
crewzer's Avatar
crewzer
Smile
Here ya go... FORscan not required!
HTH,
Jim / crewzer
Old Sep 21, 2017 | 08:27 AM
Ralls's Avatar
Ralls
11 F250 I was able to go into the fuse box and manipulate with a jumper fuse from a hot constant over to the upfitter fuse. Not saying it's correct but that's what work for me being none of the four upfitters were constant hot on the 11 model I was able to have all four hot so I can run my caution lights without the truck running
Old Sep 21, 2017 | 09:25 AM
wb6anp's Avatar
wb6anp
I have one used for one Ham radio so far, want to put in another for HF they take about 30 amps when running full power at 100 watts.
Old Sep 21, 2017 | 09:41 AM
giant futon's Avatar
giant futon
I've been considering something similar myself but I was going to go a different route. I have been looking for a multi-switch panel to wire into 5 or 6. That way the up fitter powers the switch panel and then on the panel I can select what I want to run.
The total for devices on the controller would then be under 40 amp obviously.
Similar to this:
https://www.summitracing.com/parts/p...RoCVZAQAvD_BwE
Or this:
https://www.offroadelements.com/swit...ting-hardware/
Or maybe even just the 11-16 Super Duty up fitter switches added somewhere on the console.
Still gotta research this some more.
GF
Old Sep 21, 2017 | 09:52 AM
Flyct's Avatar
Flyct
FTE Community Team
Old Sep 21, 2017 | 12:03 PM
shortride's Avatar
shortride
I plug my dashcam into the full time 12 volt power outlet in the console.
Old Sep 21, 2017 | 12:15 PM
livkot's Avatar
livkot
I am sure not all dash cams are created equal. I only know how mine is configured. Three wires involved. A constant b+, b+ accessory, and ground. My dash cam will automatically enter parking mode when accessory power is removed. I have accessory power supplied by an upfitter. Dash cam will remain powered in parking mode until vehicle power is lower than 12.3 volts or user specified.
Old Sep 21, 2017 | 12:31 PM
wb6anp's Avatar
wb6anp
what id like to do is disable the parking mode when I am home, it doesn't need to be on while there. But may end up going that way since I don't want to use my 40 amp switch. Just bought the Blackvue DR 750S-2ch. we have the 650s in the wifes car, with that accessory, it has its own switch. I was just trying to find more uses for the upfitters.
Old Sep 21, 2017 | 01:16 PM
Airstream.csh's Avatar
Airstream.csh
Although I run my dashcam on #2, if I wanted it on full-time like the OP, I'd just use #5 or #6 as the dashcam already has an inline fuse so the fuse rating on the upfitter box wouldn't come into play. If, however, I was running a snow plow or other operation where I needed #5 and #6 then I'd consider the matrix idea in Post #8, otherwise follow post #9 until you need 3 devices on all the time. Less is often more.
Old Sep 22, 2017 | 04:03 PM
wb6anp's Avatar
wb6anp
Hoked it up to switch 6 for now. Here they are.
front
Rear
Old Sep 22, 2017 | 08:10 PM
eberlestock's Avatar
eberlestock
HTH,
Jim / crewzer
Excellent info crewser! I have a company 18 duty on order and like to run my roof beacon light when the truck is off. Thanks for the info
skippyp
Feb 22, 2020 03:10 PM
Bair1218
Sep 22, 2018 11:05 PM
FOURBYBUD
Sep 18, 2017 09:36 AM
beforeiforget761
May 10, 2009 09:35 PM
Monsta
Electrical Systems/Wiring
Oct 30, 2002 03:15 PM
