Guess I'm Getting old...
Posted this in another thread. Quick wash/ clay bar (towel) and wax.
Tip from my well know detailer friend.
Optimum No Rinse
Clay Bar Towel
Optimum Spray Wax
If you have not used ONR (Optimum No Rinse) it is very easy. 2 cap fulls of ONR in a 5gal bucket + water.
Don't feel like typing our how to use... So here:
http://www.autogeek.net/how-to-use-r...hannelid=BIZRA
The trick to wash, clay bar and wax in easy.
Keep your clay bar towel soaking in your bucket with ONR.
Wash one section of your truck at a time (IE: the hood then fender etc) with ONR. Don't dry and immediately rub down with the clay towel using the ONR as lube. If it gets sticky add some more liquid from the bucket. Before you dry it spray with the wax and wipe it right off.
Gives you a quick wax job that takes less and 1hr to do on the SD.
Optimum No Rinse
Clay Bar Towel
Optimum Spray Wax
A few assorted connectors as I've added an extension hose, and all is good. This truck is so big, I've gotten best results by doing one side at a time as I find, even if I hurry, the foam on the 1st side is starting to dry, before I get back to it.
I like it. Really "lubes up the dirt" to prevent scratching. If its just dusty, foam it, rinse, blow dry and done. Still takes me 2 hours...
Originally Posted by nbayless36;17475476
[img
[img
https://cimg3.ibsrv.net/gimg/www.ford-trucks.com-vbulletin/2000x1504/80-20170417_202914_797ab3ce8ff1255759f4310dbe4c140f7d cf282b.jpg[/img]
the ruby red is definitely more work than my old Sterling Grey std cab but with the newly installed carwash the weekly baths aren't too bad
#29
Received 6,705 Likes
on
On my ATV I can suds up almost the entire vehicle and then hit it with a sponge as long as it isn't in direct sunlight and I've had an adequate dose of caffeine.
#30
I'll have to get you over to help wax my camper!! I did it by myself in the cooler months a section at a time. Moving the ladder was the hard part!! No matter how old you are keep moving and stay active if possible.
