Wont start
Old Sep 18, 2017 | 08:30 PM
ta1987's Avatar
ta1987
Wont start
I have a 79 f250 4x4 has the 400 I started the truck a month ago ran like always but I went out last week and it kept cranking I had to unhook battery I messed around with it couldn't figure nothing out except it was also killing. My spark I replace the ignition switch but got no where any help would be nice cause I enjoy driving the old truck plus its the one I turn to for all my trailer pulling in new to these forum so any help would be appreciated
Old Sep 18, 2017 | 08:35 PM
75BigBlock's Avatar
75BigBlock
Have you checked the relay between the battery and starter? Those can keep spinning the starter if they go bad, it might also keep your coil from getting any juice if it's bad as well. Worth looking into.
Old Sep 18, 2017 | 08:38 PM
ta1987's Avatar
ta1987
I will give that a try thank ya
Old Sep 18, 2017 | 10:09 PM
meangreen92's Avatar
meangreen92
Make sure you have a ground between your engine and your cab. They usually run from the bellhousing to the firewall. My truck was missing the cab ground, and did the starter run-on, until I added the ground.
Old Sep 19, 2017 | 10:02 AM
frdlvr35's Avatar
frdlvr35
Take a look at the wiring for your distributor. The wiring has a tendency to break and could be connected just enough to allow spark some times and killing spark through vibration as the connection breaks.
Old Sep 20, 2017 | 01:10 PM
D-rat's Avatar
D-rat
I had a no start issue the other day. Was my duraspark box.
Old Sep 20, 2017 | 08:05 PM
72rtchallenger's Avatar
72rtchallenger
Agree, relay solenoid , check the solenoid on fire wall and starter itself
skipper98
Jun 29, 2011 06:39 PM
reckless121691
Dec 15, 2010 09:59 AM
deepbass
1978 - 1996 Big Bronco
Aug 19, 2008 10:55 AM
etnchevys
Electrical Systems/Wiring
Apr 24, 2003 09:16 AM
BEAVER
Jan 20, 2002 02:44 PM
