volare sway bar bushing replace
Old Sep 18, 2017 | 03:15 PM
papabills54's Avatar
papabills54
little help please I have a 1954 ford f-100 with a 302 and t-5 tranny and I need to replace the outer sway bar bushings by the lower A arms. I need to jack up the front of the truck to get underneath but my question is do I need to lift the A arm and wheel to replace the bushings? Concerned about hanging pressure when I remove each side. Bill
Old Sep 19, 2017 | 11:39 AM
CharlieLed's Avatar
CharlieLed
No tension on sway bar when both wheels are level. That said, when that sway bar hangs down the angle of the bar to the lower control arm gets steep. I would jack up the truck and then place jack stands under each control arm and lower it back down to ride stance to keep the angle manageable.
Old Sep 19, 2017 | 01:15 PM
papabills54
Thanks Charlie, getting so old I have to check myself on everything. Going to do this right now and put in my new speedo cable while I'm at it. Bill
tsbrewers
Feb 23, 2012 07:13 AM
BMWM1
Jul 27, 2009 11:31 AM
zavierbr
May 27, 2009 06:25 AM
John7894
Jan 17, 2009 09:43 PM
duker61
Aerostar
Jul 22, 2002 10:17 PM
