Winter Tires
Old Sep 19, 2017 | 09:22 AM
xxxsherpa's Avatar
xxxsherpa
Good choice on the Firestones, ran them for years in Alaska.
Old Sep 19, 2017 | 12:10 PM
RightWingNutJob's Avatar
RightWingNutJob
I don't pretend to compete with Canadian Winters. I am a First Responder, so a lot of times I am out in the middle of the night before the plows.
I looked at Nokians but they were kind of pricey. Went with Firestone Winterforce and have been quite pleased. Tires are well-siped, but I had them studded because we get a lot of "mixed precipitation" (snow/ice/freezing rain) during Connecticut winters.
Old Sep 19, 2017 | 01:08 PM
HRTKD's Avatar
HRTKD
On my prior truck I ran Toyo Open Country ice/snow tires (prior model was G02+, new model is WLT1). I thought they were a very good tire for Colorado winters. They wore well as long as I didn't tow on dry pavement. I had them for probably 8 years, running them only in the winter. At the time I bought them they were almost impossible to find locally and I had to order them off the Internet.
https://www.toyotires.com/tire/patte...k-winter-tires
Old Sep 19, 2017 | 09:32 PM
COrver's Avatar
COrver
HRTKD - Thanks for posting this. I wasn't aware Toyo makes a winter tire. How well do these tires perform on ice? They look like they have pretty good siping.
Old Sep 19, 2017 | 09:49 PM
HRTKD's Avatar
HRTKD
I thought they did great on snow and ice. Every stop light was a drag strip for me when there was snow on the ground. Seriously, I pushed them hard.
My only reluctance to buying them again would be the lack of local retail shops that carry Toyo on a regular basis.
Old Sep 19, 2017 | 10:37 PM
DRKBC's Avatar
DRKBC
I live in the interior of BC and I am on my 2nd set of Nokian Hakkapeliitta's I have also run two sets of Toyo's Open Country's over the years. I seemed to scrub the Toyo's faster and they always seemed to finagle their way out of the warranty. The Nokian tires are very good, if you are going to dedicated winters the Hak is a good choice. It's a tough call between the Hak and the Rotiva's. As you can run the Rotiva's all year, the compounds not as soft so durability is better and if you don't have a second set of rims you save the changeover fees. Depends how much of your time you spend in deeper snow and colder temps. I am struggling with this myself but we get real winter here and we ski and drive to the coast etc, so mileage a side I will likely go with the Hak's again.
Old Sep 20, 2017 | 08:34 PM
DRKBC's Avatar
DRKBC
I decided to change it up and go with the Michellin LTX, I think they will be a little more durable in the end. Have to see, I have the Haks on two other trucks right now so it should be fairly easy to compare.
Old Sep 21, 2017 | 07:43 AM
triniexr's Avatar
triniexr
Thanks guy, you all confirmed my purchase of the Firestones. They are on a special right now as well so i'm going to pull the trigger on them.
Old Sep 21, 2017 | 07:46 AM
triniexr's Avatar
triniexr
I want a dedicated winter tire just in case we have a bad winter. This summer had a lot of rain so i'm expecting the winter to be a snowy one. All terrain tires even though they are rated for snow do not do a good job in snow according to this test video.
Old Sep 21, 2017 | 08:23 AM
First Dually's Avatar
First Dually
Wow...the comparison of stopping distances sure is an eye opener!
Old Sep 21, 2017 | 08:33 AM
xxxsherpa's Avatar
xxxsherpa
Siping! Must have Siping!
Old Sep 21, 2017 | 08:35 AM
HRTKD's Avatar
HRTKD
Stopping and cornering is why I buy ice/snow rated tires. The improved acceleration (and not getting stuck) is a bonus.
Old Sep 21, 2017 | 09:56 AM
  #28
DRKBC's Avatar
DRKBC
You are right, driving all seasons in deep snow or black ice just doesn't cut it. If a person lived in a climate that only gets a mild winter and was able pick and choose which days they drove, all weathers can make some sense, no switch-overs and the new tires have some pretty impressive compounds that give you traction and durability. We have a truck that will just be driven around town (not on mountain passes during the winter) we will likely go this route for that truck but only because we have other trucks that we can drive with dedicated winters for those days when it makes sense to do so.
Old Sep 21, 2017 | 10:08 AM
  #29
triniexr's Avatar
triniexr
This is why I want the best winter tire. I like my insurance rate, I don't want to rear end anyone and make it go up.
Old Sep 21, 2017 | 10:21 AM
  #30
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
This right here is truth! I run dedicated snow tires from October to April every year on all my vehicles. Same with all of my family, if they save you once they are well worth it! With our climate, once it snows it stays on the ground all winter (we hope) meaning the roads are always slick. Not like the lower 48 where it melts off after a snowfall, partly because we don't get enough heat from the sun to melt anything during the winter
I know plenty of people who say they are fine with all seasons or A/T's, they have also been in the snowbank or rear ended someone in the last few years...
