front disc brake conversion kit 58F100
Old Sep 14, 2017 | 12:02 PM
Tomget's Avatar
Tomget
Any recommendations for a front disc brake conversion kit?
Got a 58 F100 and its a pretty modded truck..pro street like with a back half 4 link suspension and a Ford 9 inch rear etc..but I'm still running drum brakes all the way around.
I was OK with that at first but lately traffic is fast and such where I live and don't feel existing brakes..although all new and in great shape..are doing enough to stop it in a panic etc.
Got some sort of aftermarket front 15 inch wheel and need the biggest and best front discs I can get to fit..Price is not a big deal, but quality and performance are.
If I could find a complete kit with master cylinder and whatever..that would probably be best..been a while since I did any brake work..I forget if I need to replace the master cylinder?..its a modern dual chamber and all..Maybe I just need add some sort of front versus rear brakes adjusting mechanism? I forgot how that works, but sure I'll find articles on same when I research.
Appreciate any help Thanks
Old Sep 14, 2017 | 09:51 PM
Walston's Avatar
Walston
I used a kit from these guys and was very happy.
Engineered Components, Inc. - Your One Stop Brake Shop!
Old Sep 15, 2017 | 12:41 AM
Tomget's Avatar
Tomget
Thanks..I'll check it out.
Old Sep 18, 2017 | 09:21 PM
Martin Torres's Avatar
Martin Torres
I am working on a '58 F100 and just bought this kit at Speedway Motors.
https://www.speedwaymotors.com/Delux...-Ton,4623.html $297.99
Came in 2 days ago but I am re-roofing the house so it will have to wait. It looks sturdy and uses parts you can replace at the auto store. Impala calipers and F150 rotors. All bolt on too.
I also bought this power booster/master cylinder at Summit. $169.97. Bolts right to the existing holes in the firewall though I will have to shorten the pushrod.
https://www.summitracing.com/parts/sum-760214
Old Sep 18, 2017 | 11:22 PM
Tomget's Avatar
Tomget
thanks much
Old Sep 21, 2017 | 01:44 AM
Rustypanel's Avatar
Rustypanel
Martin, These are the same I just ordered from the same vendors. How much did you have to shorten the push rod?
Old Sep 25, 2017 | 02:31 PM
Martin Torres
Sorry, not been on here or working on the '58. I have a roof rebuild going on and it is sucking up all my time.
Anyway, I haven't mounted it yet. The pictures were just for verification it would fit. The push rod is a 3 piece adjustable with 2 threaded male ends and a dual female center. It looks like I will have to shorten the center or buy a shorter one. I am guessing about 2 inches but will be very easy.
denny7170
Oct 19, 2016 01:05 PM
Madrid1214
Jul 21, 2015 12:52 PM
jerryst
Oct 5, 2011 10:29 PM
robbm
May 10, 2011 08:15 AM
Dave58
May 31, 2005 07:56 PM
