zf 5 speed
Old Sep 8, 2003 | 10:27 PM
muscletruck7379's Avatar
muscletruck7379
zf 5 speed
how strong is a zf 5 speed, can it handle a healthy 390 or a diesel in an old highboy 250? i've only been around one and it is ready to go anytime now, but then of course its behind a 500 horse 460
Old Sep 9, 2003 | 01:21 PM
c_rossman's Avatar
c_rossman
zf 5 speed
There are two versions of the ZF 5speed I believe in 95 on up are rated for 470 foot pounds of torque and pre 95 are 420 ft pounds of torque.
Old Sep 10, 2003 | 12:11 PM
MustangGT221's Avatar
MustangGT221
zf 5 speed
There's also a two versions that have different ratios. One for a diesel and one for a gas.
Old Sep 10, 2003 | 06:55 PM
ecarter50's Avatar
ecarter50
zf 5 speed
ZF is not available with 390 bellhousing bolt pattern.
Old Sep 10, 2003 | 07:14 PM
muscletruck7379
zf 5 speed
how is that? I thought that there was 3 in the big blocks. windsor small block,the 351c and 351m, then the bigblocks.
Old Sep 10, 2003 | 08:58 PM
StrangeRanger's Avatar
StrangeRanger
zf 5 speed
The 385 series big blocks have a different bolt pattern from the FE series. The ZF could be adapted; given enough time and money, anything is possible. If you want to put a bulletproof 5 speed in a FE powered 250, you might want to consider Advanced Adaptors kit to put an NV 4500 from a Dodge Cummins Diesel in a Ford. The kit's not cheap and neither is the tranny, but it's wrth looking into.
Daleksandrovich
Apr 9, 2014 02:17 PM
1978fordf250
Offroad & 4x4
15
Sep 24, 2012 04:40 PM
Greg5OH
16
May 12, 2012 07:50 PM
Millenium Edition
Nov 22, 2010 03:18 PM
oledog
1978 - 1996 Big Bronco
Aug 5, 2004 04:13 PM
