Air cleaner help!!
Old Sep 12, 2017 | 10:05 PM
75 F100 4X4's Avatar
75 F100 4X4
Air cleaner help!!
On my 75 f100 4x4 360 the Air cleaner has the PCV filter coming out of the housing and also what looks like some kind of a sensor. It clips to the housing and has two electrical wires that snap into a plastic housing laying on the intake manifold. Need to know what this part is called as the wires are broken and I need to replace. Thanks in advance for your help.
Old Sep 14, 2017 | 05:23 AM
KULTULZ's Avatar
KULTULZ
Question
Can you post a photo?
Old Sep 14, 2017 | 09:57 AM
75 F100 4X4
Posting pics is not my strong suit however will try. Thanks
Old Sep 14, 2017 | 10:44 AM
jakeharp's Avatar
jakeharp
mmmm
Was the fitting going into the air cleaner/pcv or is the sensor in the intake manifold ?
Old Sep 14, 2017 | 11:34 AM
75 F100 4X4
It clips into the air cleaner, close to the PCV inlet, and the other end plugs into what appears to be an electrical unit.
Old Oct 11, 2017 | 10:41 PM
jakeharp's Avatar
jakeharp
Interesting
Hopefully someone can chime in, but definitely a smog California truck ?
Old Oct 12, 2017 | 02:44 AM
KULTULZ's Avatar
KULTULZ
Post
DISTRIBUTOR MODULATOR SYSTEM
The actual part you are describing is an AIR TEMP SENSOR (Basic PN 12A164), part of the above named system.
Old Oct 12, 2017 | 10:57 AM
75 F100 4X4
Thanks for the reply. I see the part I have in the picture.
Old Oct 12, 2017 | 11:03 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
9D695 is the crankcase ventilation filter. It's retained to the air cleaner with the 9E628 clip that also retains the 384411-S elbow.
9E607 is the air temp control sensor. 9E862 is the air temp sensor override valve.
12A164 is the distributor modulator temperature ambient switch. Complete part number: D5AZ-12A164-B (Motorcraft SW-1250) / Obsolete ~ 31+ available NOS
moonshine34
26
Nov 17, 2023 02:37 AM
pogo619
Sep 24, 2017 03:56 AM
TODD LYND
Modular V10 (6.8l)
Feb 5, 2007 08:17 PM
rleptrone
1997 - 2003 F150
Dec 20, 2004 06:03 PM
ladyneedshelp
1997 - 2003 F150
Nov 14, 2004 09:55 AM
