Sponsored by: Real Truck
Ford f350 code
Old Sep 10, 2017 | 10:32 PM
Dougc357's Avatar
Dougc357
Ford f350 code
I keep getting this v0100 code in my tuner. Says lost communication with pcm/ecm? Bit truck doesnt die. Still runs but the rpms goes way higher before turbo kicks in?? Any ideas what keeps causing this? Also my cluster gauge keeps shutting off and on so the cluster is going out. I will be replacing it. Do these two problems go hand in hand?
Old Sep 11, 2017 | 05:21 AM
Just Strokin's Avatar
Just Strokin
you most likely have a loos connector some place in the CAN bus network. Changing the cluster might not fix the problem. You need to try to find the loose connector. You didn't give the year of your truck. That might be a clue since there might be a common problem on some. BTW, the error code is U0100....not V0100
Old Sep 11, 2017 | 07:55 AM
Dougc357's Avatar
Dougc357
My truck is a 2006 f350. Where is the CAN located?
Old Sep 11, 2017 | 10:37 AM
Just Strokin
CAN is the network wiring that communicates between truck modules. You have a High Speed (HS-CAN bus) and probably a Medium Speed (MS-CAN bus). How extensive it is on your 2006, I have no clue. Maybe someone will chime is that has this problem and resolved it for your year truck.
Old Sep 11, 2017 | 11:59 AM
Dougc357's Avatar
Dougc357
Lets hope so. Cause when it throws this code the transmission doesn't perform well and the turbo lacks real bad.
grogreen
Modular V8 (4.6L, 5.4L)
Apr 7, 2017 10:23 PM
KDAVID1
Feb 17, 2015 07:03 PM
vdbr1
Sep 4, 2013 07:03 PM
sand_fiend
Oct 29, 2011 10:39 PM
