Missing HO2 Sensor?
Old Sep 10, 2017 | 05:55 PM
halrhoads's Avatar
halrhoads
3rd Gear
Missing HO2 Sensor?
1996 F150 Special 5.0L - P1131 Code.
Right side manifold has a plug in it where the Left side manifold has a O2 sensor in it. Code says the lean problem is with sensor 1, Bank 1 (the right side). Is this showing because there is no sensor, or is the sensor lower down somewhere?
Sure could use some advice!
Thanks.
Old Sep 10, 2017 | 09:27 PM
Da_Lariat_Chariot's Avatar
Da_Lariat_Chariot
https://www.justanswer.com/uploads/t...s_location.gif
Looks like there are potentially three - one on each manifold (2) and one at/behind the catalyst (3). Location of the third depends on if you have CA emissions or Federal. You should have an O2 sensor in each manifold, no plugs.
Code P1131 indicates that the Bank 1 (driver side) O2 sensor is not switching/correcting rich to compensate for overly lean condition. If your sensor reads lean and the PCM is trying to enrich the mixture I would suspect a cracked exhaust manifold/leaking manifold gasket.
When you say the 'right side manifold has a plug' do you mean the driver side or passenger side?
Old Sep 10, 2017 | 10:44 PM
halrhoads's Avatar
halrhoads
3rd Gear
Bank 1: Passenger side or Drivers side.
Hmmm. I thought that Bank 1 was on the right (passenger) side (while sitting in the drivers seat, facing forward) - which contains cylinders 1 thru 4 & Left side being Bank 2, cylinders 5 thru 8.
Not so? Maybe I've bamboozled myself
There is no HO2 sensor there, just a plug. And I can't see any wiring near it.
Sigh.
Old Sep 10, 2017 | 10:56 PM
Conanski's Avatar
Conanski
The upstream sensor/s are a little further down form the manifold on most of these trucks so I'd say you need to have another look from underneath.
Bank1 is always the passenger side in a Ford truck too.
Old Sep 10, 2017 | 11:03 PM
Da_Lariat_Chariot
Dammit I forgot that.
Old Sep 11, 2017 | 08:29 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Vehicle left and right is always as seen from the driver's seat. I guess it wasn't a bad question to make sure he was 'seeing' it the same.
Old Sep 11, 2017 | 02:33 PM
halrhoads's Avatar
halrhoads
3rd Gear
Thanks everyone for the fast replies! Special Thanks to Conanski - I hadn't thought to look further back. I'll do that this afternoon.
newr
1978 - 1996 Big Bronco
Jun 12, 2015 04:32 PM
whisler
Oct 15, 2010 12:24 PM
Yogi-96blazer
17
Feb 20, 2006 09:15 AM
mudinford
Modular V8 (4.6L, 5.4L)
Feb 28, 2005 08:56 AM
MonsterRanger96
1983 - 2012 Ranger & B-Series
Mar 28, 2004 08:54 PM
