Need heater core hose help
Old Sep 10, 2017 | 05:03 PM
NICKSAN's Avatar
NICKSAN
1994, club wagon, 5.8
Years ago the previous owner had a shop bypass the front heater core in the engine compartment. Theres also a rear heater core. I bypassed that one myself at the core.
There are two hoses not connected to anything hanging in the engine compartement that are coming off two hard line tees at quick disconncts. The old heater core is still there.
Does anybody have a diagram or know where these hoses are supposed to go?
I have searched to no avail.
It looks like one might go to a line coming off the pump because there is a hose looped back and connected to a hard line with a hose clamp.
Thanks.
Old Sep 10, 2017 | 05:43 PM
85e150's Avatar
85e150
At the engine, you should have one off the pump, and one off the intake near the T-stat, like so:
http://www.fullsizebronco.com/forum/...9&d=1320586562
Looks like the one off the manifold is the "supply" hose, going into the lower heater tube.
Your hard lines should just be replacing longer rubber hoses, and should end near the heater cores with the final connection made with rubber hoses.
Do your hard lines look like this?
NOS Ford E3UZ-18B402-B Heater Hot Water Tube 1983-1986 Econoline OEM | eBay
Old Sep 10, 2017 | 06:09 PM
NICKSAN's Avatar
NICKSAN
The hard lines look similar.
Maybe a little different since theres a rear heater core as well.
I am pretty sure I traced the lines coming from the core to the hard lines but cannot figure where these loose hoses go.
Next chance I get I will see if there is a hose coming off the intake. I see one coming from the pump.
76ClydeF100
Dec 29, 2014 03:23 AM
fordboy97
Sep 19, 2014 01:11 PM
tabijan
Jun 23, 2014 06:31 AM
zed326
Jan 28, 2009 04:14 PM
epos48
Sep 30, 2004 06:45 AM
