Running Board to Rear Fender Gap, 50 F1
My 50 F1 has always had this gap between the rear fenders and running boards. I haven't noticed a gap on any other 48-52 truck that I've seen, and it's way too wide to fill with fender welting or similar. Any ideas why I have the gap or suggestions to eliminate it? I searched other threads and didn't see anything similar for a non-panel. Any ideas are greatly appreciated.
Add'l Pics
Thanks for the responses. Hers are some more pics of fitment at cab/bed and fenders to rear of truck. The rear bumper isn't re-installed yet but you can see the rear of fender to stake pocket. I don't have pics of the front because the doghouse is off (just installed MII front end), but the fit was tight in front.
The 48-52's didn't have a bushing like the 53-56's, at least not to my knowledge or based on other trucks I've seen. The gap at the bed/fender is pretty tight but gets wider as it goes towards the outside.
As you can see in one of the pics I picked up some new running boards since my pass side is dented by they measure identical to the ones on the truck now, so they'll fix the dent but not the gap. Hope the extra pics help.
that last pic the RB is damaged so I would fix that. looks to me that the fender is correct on the bed, is there filler(bondo) at the outer edge of the fender where the fender bolts to the RB? if not I might try a clamp to pull it together slowly keep the clamp low were you won't see any damage. also maybe loosen the nuts that hold the fenders on the bed and the nuts that hold the RB
The fender welting in your picture looks more like silicone. The welting I have looks more like gasket material. Where did you get yours? Thanks
Here is another view from the side and a little further away.
