1967 radio install.
Old Sep 9, 2017 | 05:07 PM
KsHighboy's Avatar
KsHighboy
1967 radio install.
I put a knobless type Pioneer stereo in my truck years ago. I cut the dash tabs out and a shop do the install. This was done 20yrs ago. My Stereo face plate was stolen and the stereo doesn't work anymore so I need to put in a new one. This time I figured I would do the Metra Volvo adapter. Took the old radio out and tried to fit the new metra adapter but it is too wide. Plus, i don't have the tabs to fold back to screw the adapter to. It's been so long ago I don't remember what the tabs looked like in a 67. I thought the Volvo plate would fit the radio opening but is the 67 a smaller opening than the 68-72? Not sure how to tackle this now.
Old Sep 9, 2017 | 07:54 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1967 F100/750 radio is 1967 only. The radio block off plate is also 1967 only.
The ash tray and dash board are also 1967 only, as are the economy & deluxe heaters.
1968/72's use a different radio, ash tray, radio block off plate, heater and dash board.
Old Sep 9, 2017 | 08:22 PM
KsHighboy's Avatar
KsHighboy
Thanks numbers! I'm looking at the pieces that came with my metra kit and have a few ideas of what I can do to make it work. A little cutting and massaging here and there. We'll see.
Old Sep 10, 2017 | 06:17 PM
KsHighboy's Avatar
KsHighboy
Numbers, the dashboard is different? Is that the pad or the whole metal part of the entire dash?
Old Sep 10, 2017 | 06:24 PM
NumberDummy
Dash is different due to the 1967 radio and ashtray and the deluxe heater, that has 3 ***** below the radio.
The padded dash is also 1967 only as is the firewall, brake & clutch pedals, bracket under the dash they suspend from.
I assume you already know about the 1967 doors...
Old Sep 10, 2017 | 06:34 PM
KsHighboy's Avatar
KsHighboy
Yeah, I know the door handles and armrest are different but I know that the window regulators fit from a 68-72 even though they say 67 is different..
Old Sep 10, 2017 | 06:43 PM
NumberDummy
'67 is different.
1967: You push the inside handles forward to lock the doors, 1968/72's have door lock *****.
1967 only: Door shells, door lock remote controls, window regulators, inside door and window crank handles, vent frames and handles, door latches, door lock cylinder rods, armrests, door trim panels.
1967/72 same: Upper/lower hinges, outside door handles, glass, division bars, weatherstrips, door lock cylinders.
Old Sep 17, 2017 | 08:47 AM
KsHighboy's Avatar
KsHighboy
Got the radio installed. It wasn't too bad. Had to grind on the dash a bit to get the Volvo adapter to fit. I also had to remove the original speaker and the bracket to get the radio sleeve to fit the dash. I wasn't using the Oe speaker anyway so it wasn't a problem. Turned out ok. Don't laugh at the flasher switch placement! The old man that owned the truck before me put it there so I left it to fill the hole.
Old Sep 18, 2017 | 03:52 AM
GaryKip's Avatar
GaryKip
The radio came out real good! That flasher switch looks fine there too. Good Job.
markzieglerinsd
51
Mar 8, 2018 08:45 PM
Gcwstang
Jul 20, 2013 12:55 PM
My4x4F150
15
Sep 15, 2010 12:01 AM
R100RT
Apr 18, 2003 11:14 AM
66_Chapel
Oct 11, 2002 01:51 PM
