radio options
Old Aug 20, 2012 | 12:44 PM
markzieglerinsd's Avatar
markzieglerinsd
radio options
OK, so I am planning on adding a "modern" radio to my '66 at some point in the future. I see the thread on adding a radio pod to the headliner and that got me thinking.
Why would someone just not cut a new hole in the dash. The only thing that comes to mind is that you want to keep the original look of the vehicle, but adding a headliner radio pod is not "original" either. I was either going to cut a DIN slot into my dash or find a remote mounted radio and install the control on the face of my dash with a few screws. The other option I see a lot of people do is add it to the glove box, but again why keep the original radio if it does not work.
Please try to pursuade me one way or the other as I am trying to figure it out before I go too far.
Mark
Old Aug 20, 2012 | 12:50 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
If there's no radio in the dash, please do not butcher it by installing something aftermarket.
Hide whatever you install inside the glovebox or under the seat.
Some peeps cut a HUGE hole in the dash for an aftermarket radio, why I dunno.
Patching that hole in the dash is a time consuming chore for purists.
The AM radios used in these trucks had tubes thru 1963. Transistors introduced in 1964.
The same radio was used in 1966/77 Bronco's. Having a radio repaired is EZ, just take it to a radio shop.
Old Aug 20, 2012 | 01:34 PM
gangstakr's Avatar
gangstakr
It's your truck do as you wish. If and when you plan to sell it the big hole in the dash is a turn off. As was said earlier, purists don't like it and when new buyers look at the gaping hole they turn there head. There is a lot of work needed to patch a hole in the dash.
After all it is your truck and what ever you do to it should be done neatly and with some thought.
The original radio weather working or not looks better than an after market radio in these trucks.
We don't want to see a post later asking how to patch a hole in the dash because you wanted to butcher it for an after market radio.
It is your truck!!
Old Aug 20, 2012 | 04:28 PM
schoo's Avatar
schoo
It is your truck!!
me to!
also their are threads posted that i have read that people have modified the radio to work like a new radio(mp3 ect) and look original.
Old Aug 20, 2012 | 05:41 PM
fordpt's Avatar
fordpt
Secret Audio.
Old Aug 21, 2012 | 10:51 PM
Shadowrider123's Avatar
Shadowrider123
We are going with xm radio.
Old Aug 22, 2012 | 08:41 AM
pburress's Avatar
pburress
I recently had the radio from my Unibody refurbished and they added a 1/8" aux jack. So now I can run my mp3 player through the glorious 1963 tubes and circuitry with an 80% loss in fidelity! Woo Hoo!
Old Aug 22, 2012 | 11:29 AM
rustywheel68's Avatar
rustywheel68
I'd say that cutting a new hole in the dash may be harder than it seems. At least...that's what i HAVE to think while staring at the massive, ragged hole in the dash of my poor '65.
i didn't do it...but i'd like to smack whoever did.
Old Aug 22, 2012 | 09:33 PM
schoo's Avatar
schoo
i saw where a guy on this site used the door from the glove bospair) to
weld up the hole from a large radio
Old Aug 23, 2012 | 08:23 AM
rustywheel68
ahhhhh...that would already have the correct curve in the metal.
i like that idea- thank you.
Old Aug 23, 2012 | 06:06 PM
markzieglerinsd
I am not saying I am going to cut a huge hole in my dash. I am just playing devil's advocate. We as "slick" truck people add power steering, power disk brakes, tilt steering columns, drop beams, electronic ignition, small block engines, ect to improve driveability. I look at a good stereo as an improvement to the driveability of a vehicle also.
I have plans to make a custom bezel to mount the new Retrosound's new Zuma radio. It has a small display and 5 push buttons much like the radio's of old. I was looking at the installation tips for their radio's and they show the display and control being removed from the main body for a more advanced installation. I am thinking that I can design a custom bezel to house the controls/display and ***** that would look just like our 61-66 radio's. But this is a lot of work for a radio when I could simply buy the Secret Audio unit and mount it to the dash but that would not look as authentic as my plan.
Mark
Old Aug 23, 2012 | 07:47 PM
gangstakr's Avatar
gangstakr
Mark
Stick to your plan, sounds like you have a handle on it. Everything you have said regarding "better diveability" is true this goes without saying. So many times I've seen a "Slick" that looks cool as hell, then you look in the cab only to see a big hole where the radio would be. That's like seeing the most beautifull woman you've ever seen, only to hear her talk and she sounds like Roseanne Barr, It's just not right.
Do your truck like you want just do it tastefully.
Old Aug 23, 2012 | 10:33 PM
Broomfieldbum's Avatar
Broomfieldbum
This is the hole I had in my dash the day I bought my truck. I found a great sheet metal welder, and now it looks like it never had a hole. As soon as I finish painting it, I will post picts. So cutting a regretful hole is not as bad as it sounds.
Old Aug 24, 2012 | 08:12 AM
rustywheel68
you haven't seen the hole in my dash.
i'll take a pic this weekend.
to the OP- i'm not against a modern stereo at all. i will absolutely have one in my truck before i put it back on the road. my cautionary statement is this: be careful. measure twice, cut once, and all that.
the difference between this modification and power steering, power brakes, ignition is that the dash is very, very noticeable.
Old Aug 24, 2012 | 10:44 PM
modeleh's Avatar
modeleh
Just thinking out loud here, but what if one found a spare glove box door and butchered the hole into the face of the door rather than the dash itself? It would cause you to lose most of the space in the glovee and you'd have to reach farther for the controls (or get a remote control unit), but you would spare yourself from being labelled "the idiot who butchered the dash" by others. Then if you wanted everything back to original someday, just replace the door with the original.
