What's everyone's fan rpms at idle? Mine vary and lately I've experience a strange issue where fan immediately locks up and rages right after cold startup. Today it was running 2900 rpm. It settled to about 480-500 but I know I'm the past it's been like 300 or so at idle.
Truck sat over the weekend and this morning when I started it the fan went to 2400 rpm for about 10 seconds and then slowly went down to about 600 rpm.
Outside temperature this morning was about 65 degrees.
I have had this occur several times before and always thought it might be related to humidity since where I live it is usually very dry (below 20% humidity) but when I have noticed this happen it has always been after a cold soak overnight and a fairly humid, cool morning.
Would be curious to hear other peoples experience with this issue/occurrence.
Are you shutting down after idling when it's really hot or with the AC on max? The clutch can stay engaged for the next start up if it's fully locked on shutdown. Depending on how much fluid is still in the clutch reservoir on shut down it might just be throwing what's already in there up on the clutches until it clears out.
I'd say 480-500 is entirely normal for a 0%DC just driving around. The chart I put up in one of the other threads shows that to be a consistent fan speed across the entire engine RPM range.
That might be it! It has been 105 degrees during the day and I have been running the air a lot.
I usually am good about shutting the air off before I shut the truck off so I'll bet the fan was just locked up due to the hot temperatures before shutdown.
FWIW I pulled up the PC-ED values book, FSS is supposed to be 425 and hot idle, 517 at 30mph, and 595 at 55mph per the table.
Thank you! Yes maybe it's ac related. I never experienced it during winter. Or at all since owning the truck for a year. It's curious how long it takes to settle down though. Maybe like 5 or more minutes.
also I thought I saw mention of a theory that the fan speed value shown on my torque app screen is the commanded value not the actual rpms but if that's true then the truck is commanding it to run 2900rpm so I don't think it's a commanded value.
I would disagree with that theory, the logs we've seen show three distinct steps of clutch engagement via the modulated ground signal to the valve in the clutch, and the rpm range of those bands varies by 200+ RPM. I don't think a viscous fan clutch could be calibrate well enough to respond to a specific rotational speed, other than "completely engaged".
5+ minutes is much longer than it should take to disengage on a cold start though. Checked all the other temp sensors to make sure they're in range? I don't recall my fan speed acting up with the TFT sensor went out (the trans sure acted up though), so unless you're still having AC problems this could be the beginning of the clutch failing. The valve leaking and filling the clutch reservoir with fluid when the engine is off, then it takes a couple minutes to spin out all the fluid at basically idle versus high speed engine operation.
