auto locking hub question.
Old Sep 7, 2017 | 11:42 AM
tjc transport's Avatar
tjc transport
i ain't rite
my 2014 has a bad vacuum seal on the passenger side front hub. therefore the auto lock function does not work. ....for now.
since i usually run the manual hubs locked all winter on the other trucks anyway, can i just lock the passenger side auto hub, plug the vacuum line at the hub, and then use the auto function on the driver side hub if 4X4 is needed this winter?
i don't have the time or money to fix the seal at the present time, and most likely will not be able to replace the seal until next year.
Old Sep 9, 2017 | 07:33 PM
meborder's Avatar
meborder
Lock them both. Otherwise the locked side will be turning the front driveshaft through the spider gears, or worse, the axle shaft on the unlocked side will be turning backwards depending on which has less friction.
Either way, this seems like unnecessary wear on the spider gears.
Just lock them both in until you get the vacuum problem fixed.
My $0.02
Old Sep 15, 2017 | 03:58 AM
projectnitemare's Avatar
projectnitemare
My $0.02
I'll second that
EricE
May 29, 2018 09:08 PM
6.0f350newb
Jan 11, 2011 06:50 PM
RAGaz
Jun 18, 2010 10:42 AM
swann79
Nov 2, 2007 12:54 AM
camsamjam
Mar 21, 2006 04:51 PM
