Calculating tow capacity for a 76 F250?
As long as, when loaded, each axle weight is less than that sticker (and hopefully a fair bit less), I should be good - after all the work on suspension, brakes, etc to bring it up to snuff.
Going by the Marti report, my truck is a bit of a mutt. It says Light Duty towing package, but then mentions some of the heavy duty package:
Front & Rear Heavy Duty Shocks
Heavy Duty Rear Springs
Auxiliary Rear Springs
Oil Pressure Gauge
Ammeter
It doesn't mention the HD emergency flasher, transmission oil cooler, auxiliary oil cooler, HD battery (80amp-hr with the 460), HD alternator (60amp) that are also part of the HD Towing package, so I will have to look and see if I can see them. The original owner could've just ordered the Light Duty package and then the heavy duty suspension bits as single options, I suppose.
mgf250
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
04-13-2008 02:04 PM
wcurtis
Conventional (Bumper Pull) Towing; Travel Trailers & Pop-ups
01-11-2007 08:09 AM
cjsmonnie
11-07-2004 05:14 PM
