96 Ranger headlamps
Old Sep 8, 2003 | 07:11 PM
parkranger's Avatar
parkranger
96 Ranger headlamps
Does anyone know how to adjust the headlamps on a 96 Ranger? There seems to be only one set-screw visible on the radiator-side of each headlight.
Old Sep 8, 2003 | 08:10 PM
Ken00's Avatar
Ken00
96 Ranger headlamps
Welcome to FTE!!!
I'm sure someone will be able to help, I'm not familar with the mid 90s lights.
Old Sep 8, 2003 | 09:36 PM
Peter94's Avatar
Peter94
96 Ranger headlamps
I belive the 96 has the same headlights as my 94, lets start with the drivers side light, when your facing the light, on the left hand side there should be what looks like the end of a screw facing out twards the engine, if you notice, the end of the screw has a box end on it, if you can find a socket small enough give it a turn, this should move the light either up and down, or left to right, I think its left to right, the other adjustment is on the right hand side, its going to be alot lower than the one on the left was, it helps if you have a socket with a long handle, this should adjust the up and down movement of the light. remember, the screw on the right hand side is alot lower than the one on the right. Hope this helps, ~Peter
