Is my engine the original??
Old Sep 8, 2003 | 05:50 PM
94matt's Avatar
94matt
Hey guys,
I was just out scouting out the truck to see what I need to do next, and noticed the oil drain is in a weird spot. The sump of the pan is toward the front of the engine, right above the frame crossmember. The drain plug is in this area, is this normal or is this maybe not the original engine?
PS, the engine in question is an FE which according to the truck is a 360. Any help in confirming the identity of this motor is greatly appreciated.
Matt
Old Sep 8, 2003 | 06:02 PM
Comegetsome's Avatar
Comegetsome
The front sump is standard for most FE's. As to whether or not your engine is original, you'll need to check the VIN plate and cross reference that to your engine ID.
Old Sep 8, 2003 | 06:05 PM
mypa'struck's Avatar
mypa'struck
and it is a pain in the **** when you change your oil too. splatters all over the crossmember no matter how careful you are.
Old Sep 8, 2003 | 06:11 PM
Comegetsome
Take a length of breather hose, a short funnel with a wide mouth and a hose clamp. Voila! No more mess. Works great for me.
Old Sep 8, 2003 | 06:15 PM
94matt's Avatar
94matt
Thanks,
I'm pretty confident it's the original motor, just was thrown off by the drain location. This truck was my girlfriends grandfathers truck from day one, and no one mentioned anything about a new engine to me.
Thanks again
Matt
Old Sep 9, 2003 | 07:33 AM
lee's Avatar
lee
Matt,
To check the date your engine was "born" on look for the date code. Easy way to find it is laying under the truck and look up at where the oil filter screws into the adapter/block. Cast into the block at this location you should find a date code. It will be in the format of "7A10". This would translates to 1967, Jan 10. See if this date is the same as the year model of your truck.
When I first bought my 1970 truck I found my code (7A10) to not match the year model. Engine swapped!
Take care,
Old Sep 9, 2003 | 11:49 AM
pward76's Avatar
pward76
Hey Matt,
I asked the exact same question for the exact same reason when I first joined.
I thought "why in the world would an engineer think to put the plug over the crossmember?"
I have an old pie tin that I cut the bottom out of on one side. Slide that baby up onto the crossmember, take out the drain plug, and viola - the oil hits the pan, flows across to the hole, and into my catch pan - no oil on the crossmember!
Old Sep 9, 2003 | 04:48 PM
dotcentral's Avatar
dotcentral
Were FE's put in trucks from the beginning of the FE production, or after the phase out of the old "Y" blocks? I wouldn't be surprised to learn that Ford wasn't in a hurry to develop a truck only oil pan for the FE, and since the existing pan physically fit, why not use it and save a few bucks. Is the plug in the same spot for 73-79's? It seems like my Dad's '74 was away from the crossmember, but that was twenty-some years ago.
Old Sep 9, 2003 | 05:05 PM
lee's Avatar
lee
Hi,
There are rear sump oil pans for trucks as far back as 1970. I know this because that is what is on my truck. Being that it is a 4x4 the front sump pan would not fit as the front axle is in the way. Hence the need for a rear sump pan.
Take care,
Old Sep 9, 2003 | 05:09 PM
BB's Avatar
BB
292 Y blocks were put in pickups up to '64.
'65 was the year for the FE in a pickup, plus Twin I Beams too!
Barry
