ARB air locker
Old Sep 4, 2017 | 08:17 PM
Tex68w's Avatar
Tex68w
ARB air locker
I am considering adding an air locker to the front axle, if I'm correct in my assumption, the front axle is still the same on the 2017 as it was on the previous generation?! Ford calls it a Super Dana 60, but I am pretty sure it's a Dana60HD 35 spline. I have a diesel with 3.55 gears which means I would need the RD167 model locker? ARB Air Locker Dana 60hd 35 Spline 4.10 & Down (RD167)
Which model compressor do you guys recommend and where would you recommend I mount it? Could I get away with running it to one of my aux/upfitter switches or would I be better off running the rocker they provide with the locker?
Thanks in advance for any help/insight!
Old Sep 4, 2017 | 08:40 PM
Ricohman's Avatar
Ricohman
As you know you need 2 switches. I don't know if I would mount them in a place that anyone else but the driver would be able actuate them. So this would eliminate the use of the upfitter switches.
I have never used the provided switches though as I found toggle gear easier to use.
Old Sep 4, 2017 | 09:42 PM
DeputyDiesel's Avatar
DeputyDiesel
Why not go with an e-locker like the rear? Does an air locker have an advantage?
Old Sep 4, 2017 | 09:58 PM
Tex68w's Avatar
Tex68w
I could get an Eaton E-locker, I had one in a Jeep a decade or so ago, maybe I should poll here and see which gets more votes?!
Old Sep 4, 2017 | 10:00 PM
Ricohman's Avatar
Ricohman
Strength. But that can be debated as eaton makes a strong unit.
You can use the compressor to air up tires.
I prefer the ARB but maybe an elocker is less complicated to install.
Old Sep 4, 2017 | 10:06 PM
DSLTRK60's Avatar
DSLTRK60
What about an OX locker? Fully mechanical design, and you dont have to drill the housing for an air line. Plus you get a thick steel cover. Made in USA also.
Old Sep 4, 2017 | 10:13 PM
Tex68w's Avatar
Tex68w
Had one on a Jeep Cherokee in college, wasn't a fan of the linkage and long cable. Sometimes it was difficult to disengage and on a truck like this it feels almost too simple and out of place. In the end it'll be an ARB or Eaton.
Old Sep 4, 2017 | 10:20 PM
DSLTRK60's Avatar
DSLTRK60
They make them electric and air actuated now as an option. I just don't like drilling into the diff housing. Supposedly the locking ring has been updated to avoid hard shifts. I installed one on my yj and it shifted like butter and is very strong. I've heard they can be sticky if the cable isn't adjusted correctly.
Old Sep 5, 2017 | 03:24 AM
Large's Avatar
Large
ARB air lockers are instant on / off. The electric lockers come on when they want to and are sometimes finicky.
Old Sep 5, 2017 | 10:21 AM
DeputyDiesel
Does anyone know what brand ford uses from the factory?
Old Sep 5, 2017 | 12:40 PM
Tex68w's Avatar
Tex68w
I would assume that it's a Eaton or Auburn, but I have no idea honestly.
Old Sep 6, 2017 | 02:24 AM
willynilly's Avatar
willynilly
electric are on /off also. if they dont engage right away it can meen a few things. there might be a mechanical or electrical problem somewhere or the sensors need cleaned. your not likely to experience these problems however.
the main reason lockers dont engage right away is because people flip the switch on hard pack roads and the engaging teeth arent in a position to mesh. one wheel must turn allitle further for engagement to take place. a S turn driving motion is is usually whats needed and the owners manual usually makes this perfectly clear. in snow or mud where the tires can easily turn at different rates, it should lock right after the button is pushed. i know this because ive got a toyota and ram with elockers
4x41977
May 22, 2012 07:35 PM
afonda
Feb 27, 2012 01:00 PM
00PwrStrk73
Sep 10, 2010 06:14 AM
tbaker00
6.7L Power Stroke Diesel
Jul 4, 2010 01:55 PM
tarvis_78
Offroad & 4x4
44
Mar 30, 2004 03:07 PM
