Blue spring upgrade
Old Sep 4, 2017 | 11:29 AM
2006fordf25060's Avatar
2006fordf25060
Blue spring upgrade
Hello, I've been told many times that the blue spring upgrade is great for 6.0 so I'm finally getting around to doing it but I have a few questions about it. What exactly is it? Is it something I can install myself? Which one should I buy, I've seen one for $170 but then I've seen one for $20. Is there much of a difference? For you guys that have could you link me to the one you bought? Anyway thank you in advance.
Old Sep 4, 2017 | 11:55 AM
navistarnut's Avatar
navistarnut
Pretty easy mod if you can turn a wrench you can do it yourself, increases your fuel pressure to keep the injectors happier. It's a no brainer, really.
Get the Ford kit, it's proven and not expensive
Part# is 3C3Z-9T517-AG
Here is a vid from DTR. I did one a few days ago, took around half hour. Only difference was I was changing the fuel filters so I took the upper filter out, and then used a turkey baster to suck the fuel out so it doesn't run all over creation when you take things loose.
Old Sep 4, 2017 | 12:06 PM
Texas Bob's Avatar
Texas Bob
The blue spring upgrade will increase your running fuel pressure to over 60 PSI and I am told this is a good thing. I was running around 50+PSI and I was having a leak on the fuel line input so I elected to upgrade. Try Riff Raff Diesel for a fair deal. My cost delivered in 2014 was $42.38. Riff Raff are good folks and they will provide the correct parts. Google for how to install-it is quick and easy.
It sounds like you may be new to the 6.0 world so I would recommend you purchase a some sort of monitoring device. I use a Scanguage II which can be purchased at Autozone and on the web. I also have installed a Glowshift Fuel Pressure Gauge which cost about $100 back in 2013. With these you will be able to identify many problems before they become critical.
Good luck.
Old Sep 4, 2017 | 12:11 PM
diesel_dan's Avatar
diesel_dan
I bought mine here:
Ford Fuel Pressure Regulator Blue Spring Kit - Riffraff Diesel Performance
Good folks to deal with...
One difference in the way I did mine is I took off the hard-line hold down on the driver's head. That allowed me to just swing the cover out and do the parts swap w/o breaking loose the fuel line connection.
and lube the new o-ring for the cover...
Pretty easy if even I can do it....
Scott
Old Sep 4, 2017 | 02:03 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
X2 on ^^^, I ordered mine from Riff Raff.
Old Sep 4, 2017 | 02:38 PM
TooManyToys.'s Avatar
TooManyToys.
Are the kits in a Ford or Nav package?
Old Sep 4, 2017 | 03:21 PM
diesel_dan's Avatar
diesel_dan
Not sure today, but 4 years ago I'm pretty sure it was Ford/Motorcraft. Looks like a Ford PN, but even on RiffRaff's site they say manufacturer is Navistar...
Scott
Old Sep 4, 2017 | 05:01 PM
Yahiko's Avatar
Yahiko
FTE Remembers
I got my kit from HI so that makes it a Navistar.
A lot less money than from Ford for the same thing.
Old Sep 4, 2017 | 06:16 PM
navistarnut
Mine came in the Ford package, of course it would since I ordered it from Autonation with a bunch of stuff
Old Sep 4, 2017 | 07:01 PM
TooManyToys.
Yes, yes they would be ......
I should have been specific, Riff Raff's version.
Old Sep 4, 2017 | 07:28 PM
navistarnut
Jack, it seems I forgot to take my COQ10 again today
Old Sep 4, 2017 | 07:37 PM
TooManyToys.
I forgot to as well, hence the non-specificity.
But I got mass quantities of Mag in
Old Sep 4, 2017 | 07:59 PM
Monster-4's Avatar
Monster-4
I just did mine today. The International bag on the right was inside the Ford bag on the left. The International sticker was blacked out. If you flip it over you can make out the International logo still.
Old Sep 5, 2017 | 01:06 AM
Yahiko's Avatar
Yahiko
FTE Remembers
Any people want to know why Ford dealers charge so much.
Even going well over the Ford MSRP.
Old Sep 5, 2017 | 03:15 PM
Bently_Coop's Avatar
Bently_Coop
Privately owned dealers.
