Starting on a 351c
Old Sep 4, 2017 | 12:22 AM
truckguy933's Avatar
truckguy933
Starting on a 351c
Hey guys its been a while" I recently decided to start building another engine while im playing around with what I got' I want to experemint with the 351c, looking for something a little racy, wanting to make the chevys quiver a bit, I got me a good solid block with refurbished factory crank and rods with arp bolts,' later on over time I want to get hypereutectic flat top pistons 11:1 compression,refurbed 2v or 4v closed chamber heads, edelbrock torquor 2 manifold, 800cfm carb high am msd ignition, 290hr cam k kit specs are 2500-6000 578/578 230/230@.50 duration 110lsa, big tube full length headers 3 primary 3 inch dual exhaust through borla atak mufflets, for trans is a c6 shift kit 3000 stall 4.11 gears it would be replacing my 390 in my swb 68 f100, 3900lbs on scale with me in it,
Looking for upwards of 500hp and tq, wanting to be in low 12s in the quarter, would this be enough to cut it? im still a novice I've only really been into my 390 I built, but I am aware this probably won't be a street friendly combination and it will need race fuel but once I get this over, the truck is only going to be a strip truck, maybe once in a while drive to the store for a pop, thanks for the help in advance
Old Sep 4, 2017 | 12:31 AM
85e150's Avatar
85e150
351c nice motor..real nice. But you have a 390, just pop a stroker kit in it for 445 cubes and get some real power.
Serving suggestion.....
Old Sep 4, 2017 | 09:22 AM
truckguy933
Sure is a suggestion! But I want to expand my knowledge of a new engine plus I already got me a machined block, crank and rods for 1200$
Old Sep 5, 2017 | 12:18 PM
beartracks's Avatar
beartracks
351c was not meant for torque and that's what a truck needs.
Old Sep 5, 2017 | 01:58 PM
buckin69bronco's Avatar
buckin69bronco
Seeing that the 351c has the same bore and stroke as a 351m and a very similar bore and stroke to a 360 (4.00 x 3.5 vs 4.05 x 3.5) there is no reason a 351c couldn't be built for torque and work great in a truck.
Old Sep 5, 2017 | 11:18 PM
truckguy933
my goals is to build the Cleveland to race not for the street
Old Sep 5, 2017 | 11:29 PM
85e150's Avatar
85e150
Fordss2003
24
Jan 2, 2019 07:53 PM
Turbo Dog
Feb 11, 2013 05:14 PM
ynevada
31
May 27, 2009 10:11 PM
1969Highboy
Mar 6, 2009 08:10 PM
gtex
Apr 25, 2003 12:04 PM
