Headlight Assembly
Old Sep 3, 2017 | 08:43 PM
Aarons54f100's Avatar
Aarons54f100
Headlight Assembly
Hey fellas,
I am looking to get headlights in my 54 and am missing 100% of the parts aside from the grill. I do have the parking lamps. Does anyone have a diagram of how they are assembled or something that shows what all parts are required?
Are led bulbs a thing in these old trucks?
Old Sep 3, 2017 | 08:56 PM
abe's Avatar
abe
You should have a shop manual. Check eBay for good used ones or buy a reproduction. Or at least call MidFifty and get a free catalog. They have lots of pictures and diagrams.
There are headlight buckets, springs, retainer for rings, etc, with a trim ring as the last piece .
Someone might be along later to post a diagram for you.
Old Sep 3, 2017 | 09:01 PM
Aarons54f100
Yeah I have a stack of catalogs. They don't really show what I am looking for. My shop manual is at the shop. But I appreciate your post.
Old Sep 3, 2017 | 09:34 PM
Harrier's Avatar
Harrier
Does this help? Are you 12V or 6V? Led lights are available, but it is more difficult for 6V. I haven't bothered trying.
Old Sep 3, 2017 | 09:58 PM
Aarons54f100
Awesome this is what I am looking for! I am 12v. I wonder if Led is worth the effort. I've seen the Halogen ones with amber leds built in.
Old Sep 3, 2017 | 10:13 PM
Vanquish Auto's Avatar
Vanquish Auto
Former Vendor
Vanquish Auto LED Headlights
I got some led bi-led I would recommend. Do not get led on reflectors, the cutoff is not good.
Here are are the better ones
https://vanquishauto.com/2007-2017-j...placement.html
no need to get adapters or cancellers. Use coupon code SAVEME20% at checkout.
Old Sep 4, 2017 | 01:19 PM
petemcl's Avatar
petemcl
Here is the pinout for the standard headlamp if you need it.
Old Sep 4, 2017 | 03:07 PM
Aarons54f100
Thanks for posting the pin out. I ordered all my stuff this morning. I went with some of those LED halo lights on sort of an impluse purchase. I like them on everything I see them on. We'll see if I regret it later.
Old Sep 4, 2017 | 04:05 PM
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Be sure to post pictures once you get them installed.
Old Sep 14, 2017 | 10:32 PM
Aarons54f100
I got one of them Installed, I am pretty happy with them to be honest. There is a tab that sticks out up top on the headlight bucket. I thought about cutting it off but saw that the one from the shop manual had it as well.
Old Sep 15, 2017 | 05:20 AM
Harrier's Avatar
Harrier
Wow! Very nice!
Old Sep 15, 2017 | 08:06 AM
56panelford's Avatar
56panelford
I have them on my pickup too, I like them. I have them so they come on with switched power and use them as daytime running lights. Main reason I got them..
Old Sep 15, 2017 | 08:23 AM
petemcl's Avatar
petemcl
Very nice. Do they have a turn signal incorporated?
Old Sep 15, 2017 | 08:28 AM
56panelford
You can get them with that Pete..
Old Sep 15, 2017 | 09:02 AM
Aarons54f100
You can order the LEDs in amber for turning signal. But they are not dual purpose. I am running the turn circuit to the bulb underneath the headlight assembly and have amber lens to replace the old clear ones.
I like having the clear LEDs but they as they are currently wired they only come on when the switch is out halfway and they shut off when the headlights are on.
I could wire them to the tail light circuit to get them to stay on anytime the light switch is used.
The other possibility is to take ignition switched hot to make them daytime running lamps.
