Anyone install a flatbed yet?
Old Sep 3, 2017 | 03:19 PM
17PSD's Avatar
17PSD
I have seen a few but most people don't seem to be converting these over.
I would like to put a nice simple deck on my f350 cc lariat. If anyone has put on on their trucks yet please post up and share your setup.
thanks.
Old Sep 3, 2017 | 08:40 PM
gbkeith's Avatar
gbkeith
I've got one. The dealer screwed me and the truck was way late in showing up. The flatbed was a rush job because of that and it ended up sitting a couple inches higher than I'd have liked and weighing a couple hundred pounds more than it should have. Overall I am pretty happy with it though.
Old Sep 4, 2017 | 02:06 PM
Notmeofficer's Avatar
Notmeofficer
Beautiful truck,, and just the right welder One of the best field welders in the industry
Bed looks very beefy..almost medium duty beefy. I understand what you're saying about height.. looks like you wanted the headache rack bar to line up with the body line...and the toolbox to line up with the lower body line... but in the end.. you've built a really nice usable rig
Old Sep 4, 2017 | 06:00 PM
BowtieConvert's Avatar
BowtieConvert
Are you guys doing a bed delete or ordering the cab & chassis with the de-rated 6.7 PS? I am contemplating doing the bed delete but in the end I think that will end up costing me too much. The hp & torque #'s on the 6.7 PS cab & chassis are similar to my '15 D-max so I can live with that. Any experience with the de-tuned engine? Thanks.
Old Sep 4, 2017 | 07:40 PM
gbkeith's Avatar
gbkeith
I did a regular pick up with bed. That got me the full power engine, 3.55 ratio, spare tire w/carrier, and 3" hitch. If you do a bed delete on a regular truck you save five or six hundred but you also lose the hitch and spare. On a chassis cab srw you lose the hitch, get the detuned engine, 3.73 axles, and a couple other things that I can't recall right now. Tow ratings are also lower I believe. It is easier to mount a flatbed on the chassis cab frame but it's not a big deal. I kept the bed but could have sold it to the place that put the flatbed on. We end up having to replace the bed on a truck every few years so having an extra on hand can't hurt. So for me buying a truck with a bed was a no brainer.
Thanks, I didn't build it though. I was in a big squeeze for time so a local place did it. They had it on hand. It was what they called an oil field spec bed. The diamond plate is 3/16 instead of 1/8 and there was something else heavier about it. It wasn't made for a '17 Ford. The top of frame to top of cab distance on a '17 is higher than anything else so they had to space it off the frame to get the top of the headache rack high enough. It's not ideal but it works pretty well. Hopefully I can do better on the next one in '22.
Old Sep 4, 2017 | 10:40 PM
reseehc_99's Avatar
reseehc_99
I remember seeing a post from a member here that had a custom flatbed made and painted to match (Caribou IIRC). Hopefully he'll chime in. If not I'll try to find the post he made.
Old Sep 4, 2017 | 11:37 PM
reseehc_99's Avatar
reseehc_99
Found it:
https://www.ford-trucks.com/forums/1...-tow-body.html
Old Sep 17, 2017 | 09:20 PM
17PSD's Avatar
17PSD
Thanks for the info guys,
Trucks look good. I really like the functionality of a deck vs bed. The search continues. I like the idea of aluminum but not sure if steel makes more sense.
Hai Nhi
May 11, 2018 12:25 PM
FunknFord
16
Feb 11, 2011 06:37 PM
kaotikedge_111100
17
Nov 21, 2003 07:39 AM
lilman20815
Jun 12, 2003 10:54 AM
