Compression ratio
Old Sep 2, 2017 | 10:21 PM
Isaiah Fred's Avatar
Isaiah Fred
Compression ratio
So I'm starting to look and research top end kits and components for a rebuild/upgrade to the stock 302. What I need though is the compression ratio for that sock 1981 302 engine. Would anyone happen to know these specs and if any engine builders out there have advice chime in.
Old Sep 3, 2017 | 12:10 AM
85e150's Avatar
85e150
Lowish. If you want a runner, late model Explorer heads are the answer. Dozens of questions are like this in the SBF forum. Look for Conanski, he has memorized all configurations of the SBF and knows which ones truck and which ones su... are in need of correction.
Old Sep 3, 2017 | 12:13 AM
85e150's Avatar
85e150
Example thread. I note you are in CA, so you will have to retain OEM smog equipment, intake and carb and appearance. Read on, good luck, and BTW welcome to FTE:
https://www.ford-trucks.com/forums/1...reshen-up.html
Rembrant
34
May 18, 2018 07:47 AM
littleme13
Jun 30, 2007 05:23 PM
old75F-100
15
Mar 13, 2006 07:44 AM
Tronick
Mar 1, 2003 04:54 PM
