Install distributor
Old Sep 1, 2017 | 11:14 PM
JosePrado's Avatar
JosePrado
Install distributor
Hello again folks -
I will install a distributor on my recently rebuilt 240 engine.
Long story made short: the distributor needs replacement and I'll have to do it before I can take the truck back for some other details.
I went through YouTube to find some instructions on how to do it.
Didn't really see anything specific to my truck.
I suppose it shouldn't matter all too much.
This was probably the best one:
What do others think?
thanks
Old Sep 2, 2017 | 12:35 AM
GaryKip's Avatar
GaryKip
I think that She can work on my truck anytime. The fact that she used a Chevy may mess you up. Number one is on the passenger side on a 360/390. But since I see that that you have a 240, finding #1 should be a little easier-lol. What year is your truck?
Old Sep 2, 2017 | 12:44 AM
JosePrado's Avatar
JosePrado
I figured I'd get a funny response like yours...
Truck is a '69
Thanks
Old Sep 2, 2017 | 12:51 AM
GaryKip's Avatar
GaryKip
Do you need a manual?
Old Sep 2, 2017 | 09:58 AM
lee's Avatar
lee
It's practically the same principle no matter the engine.
Ensure that #1 is at TDC on compression stroke.
Rotate rotor till it's a little before the #1 post of distributor. Then insert distributor. I say alittle before because as the gears mesh the rotor will "rotate" into position.
Old Sep 2, 2017 | 10:14 AM
JEFFFAFA's Avatar
JEFFFAFA
2x. And also one should note where the Dizzy housing is before one removes the old one. Like mark with chalk on the vehicle or engine where the vacuum advance nipple is pointing. Then install the new Dizzy with it's nipple pointing at that same spot. This will pre-set the ignition timing darn close. The engine will fire right up. The timing should then be checked though.
Old Sep 2, 2017 | 07:04 PM
jfmaz's Avatar
jfmaz
Anyone ever had the oil pump drive drop into the pan when changing distributors?
Old Sep 2, 2017 | 08:49 PM
DirtyFerd's Avatar
DirtyFerd
That's why you put the little ring on the oil pump shaft on top. It keeps you from pulling the shaft up.
NS70250
15
Sep 11, 2015 07:43 PM
TexasTrash
Jan 26, 2010 08:56 PM
mlevario99
Apr 24, 2008 09:18 AM
4.9inline6
Feb 2, 2006 07:02 AM
daveengelson
13
May 26, 2004 12:03 AM
