Drive shaft length
Old Sep 1, 2017 | 09:29 PM
big ole ford's Avatar
big ole ford
Drive shaft length
I am going to switch from a c6 to a t-19 in my 86 crew cab dually 4x2 does anyone know what length I would need for the t-19 or if the c6 shaft will work. It is a 2 piece shaft so i may only need the front half, the c6 uses a slip yoke while the t-19 uses a bolted yoke if that matters. I have everything I need to do the swap except the driveshaft and that's where I need advice. Thanks
Old Sep 2, 2017 | 07:24 AM
Franklin2's Avatar
Franklin2
Looks like you are the 9th one down on the list. Different from the others, I am guessing you are going to have to get yours lengthened or shortened.
155" WB, AT, rear section
155" WB, MT, front section
155" WB, MT, rear section
155" WB, AT, front section
168" WB Crew Cab, AT, 4x4, front section
168" WB Crew Cab, MT, 4x4, front section
137" WB, AT, 4x4
137" WB, MT, 4x4
168" WB Crew Cab, AT, 4x2
133" WB, AT, 4x2, 1 piece
133" WB, AT, 4x2, 2 piece (assembly)
133" WB, AT, 4x4
133" WB, MT, 4x4
137" WB, AT, 4x2, 1 piece
161" WB Chassis Cab, MT, New Process manufactured transmission (assembly)
161" WB Chassis Cab, MT, Warner manufactured, T-18 transmission (assembly)
161" WB Chassis Cab, MT, Warner manufactured, T-19 transmission (assembly)
133" WB, MT, 4x2 (assembly), New Process manufactured transmission
133" WB, MT, 4x2 (assembly), Warner manufactured, T-18 transmission
133" WB, MT, 4x2 (assembly), Warner manufactured, T-19 transmission
137" WB, AT, 4x2, 2 piece (assembly)
137" WB, MT, 4x2 (assembly), New Process manufactured transmission
137" WB, MT, 4x2 (assembly), Warner manufactured, T-18 transmission
137" WB, MT, 4x2 (assembly), Warner manufactured, T-19 Transmission
168" WB Crew Cab, AT, 4x4, rear section
168" WB Crew Cab, MT, 4x2, assembly (Warner T-19 transmission)
168" WB Crew Cab, MT, 4x2, front section
168" WB Crew Cab, MT, 4x2, rear section
168" WB Crew Cab, MT, 4x4, rear section
161" WB Chassis Cab, AT, (assembly)
Old Sep 2, 2017 | 07:28 AM
Franklin2's Avatar
Franklin2
Actually, these two places in Georgia say they might have one.
1988
Rear Drive Shaft
Ford Truck F350 not Super Duty A 00003986 $75 Haynes Auto Parts USA-GA(Commerce) E-mail 706-335-5166 / 404-524-4038
1988
Rear Drive Shaft
Ford Truck F350 8-87,CAT, WHITE 160009 $50 A and B Auto Salvage USA-GA(Griffin) Request_Quote 770-229-9122 Request_Insurance_Quote
Old Sep 2, 2017 | 07:36 AM
big ole ford
Did you get that off car-part.com? I did not think to look for a later model and I don't guess it matters long as it's for a crew cab with a t-19. Thanks
Old Sep 2, 2017 | 08:19 PM
Franklin2's Avatar
Franklin2
I plugged in your year and model, but car-part does list other compatible year trucks also.
Old Sep 3, 2017 | 08:28 AM
Nothing Special's Avatar
Nothing Special
.But you've got to be careful with what car-part thinks is compatible (and they even warn you about that). I was just looking for a steering wheel for a '96 F-250HD (I know better than to look for one for a '97...) and it was happy to tell me about steering wheels out of '96 F-150, which has an air bag while the F-250HD does not. So I wouldn't guarantee that they're taking all of the applicable options into account. You need to call the seller and make sure it's what you need.
Dace
WTB - Ford Trucks & other vehicles
Jul 14, 2015 08:42 PM
jdbanks
51
Apr 13, 2012 02:08 PM
tootsie
Jan 13, 2011 03:45 PM
fastfrank
Mar 20, 2002 10:29 PM
