General Diesel Discussion
Need help 06f-250
Old Sep 1, 2017 | 02:43 PM
06f-250's Avatar
06f-250
Need help 06f-250
Truck started hesitating and losing power after 2000 rpm. We put icp sensor new tempature sensor and four right side injectors also a high pressure oil rail kit . It has a brand new turbo also.i don't have any gauges other than what's on truck. I used a scanner and it says turbo under boost but it actually has a over boost.and it doesn't wanna go over 2000 rpm . Also little white smoke when I pull away from a stop . When it's cold doesn't wanna shift . When it's warm I can push pedal down and it takes about 20 seconds and takes off like it should , very powerful and my boost comes back down where it should .dont know if I should do other injectors cause it did get a little better but not much . Or if it's hpop.also this is my first post and I'm new to this thanx
Old Sep 1, 2017 | 10:43 PM
82_F100_300Six's Avatar
82_F100_300Six
If you look in the 6.0 section there are two million threads like what you are describing. Might want to make a pot of coffee and read up.
Joes1stdiesel
Sep 26, 2012 09:23 PM
Dirtrider0213
Mar 10, 2011 10:46 PM
Culvert
Sep 7, 2009 03:59 PM
79F150EFI
Oct 9, 2006 07:38 AM
brabe
Dec 2, 2003 12:12 AM
