Ok, with the tow ratings, I find that Ford likes to play it safe, but that tow rating is with the POS Mazda tranny, which in mine has towed my 4200lb car and a 1000lb trailer...so an auto can defintely pull the same weight, and alot easier i think....at least over hilly terrain, (which I would not suggest with either) But for your quistion, yes It can be done, just pay attention to your truck, if something seems amiss...stop, and check it out...
4.2 is a tough ol beast i had my 97 short bed slam loaded with brrick and block no clue on the weight but probly around 3500-4000 lbs truck towed it just fine but i did blow 1 of the shocks out
I have a 97 4.2 with manual transmission. I pulled a trailer rated for 7000 # carrying 3.44 tons of crushed concrete with no problems. I only hauled that much once but I would do it again if needed. I did this on the bumper. You should just take it easy and not be in a hurry. Good luck...
I towed a 16 flat bed with a jeep and a4wheeler and 800LBS of deer corn from houston th brackettville tx last week. I've got a 2003 xl 4.2 5 speed and ran 65 the whole way, The breaks are my biggest worry. I wanted to take the Big truck but the wife had other plans....
Jimmy Dean
The 4.2 in the half ton truck does do a good job towing. I did trash the 4.2 in my 97 because of the head gasket problem that it seems all 97-98 are having. Mine has been rebuilt now and is again running great. From what I now know, I should not have the same problem again because it was a faulty head gasket that is now known by all to be defective. I had to eat the expensive repair cost and that should not be the case. The 4.2 is a good engine on one hand but the other hand holds the cash that it takes to repair the 97 and 98. The stats speak for themselves...Carker
