heater blower issues
Old Aug 31, 2017 | 11:55 AM
mudrat025's Avatar
mudrat025
1995 ford f350.the squirrel cage on my heater fan motoe split last week taking out the shroud.to my surprise there is basically no replacements and since basically all the wrecking yards are shut down around here for stealing cars and crushing i decided to do some plastic welding.got the shroud fixed and hooked up the new motor to it only working on high.old motor also....was working on all speeds before the incident.all fuses and relays seem to be fine.any thoughts of what this could be gentlemen?
Old Aug 31, 2017 | 12:44 PM
pwjackson42's Avatar
pwjackson42
I had to replace the fan resistor that controls all the speeds, they can be picked up at most auto parts stores. I believe it is a white/cream colored connector with maybe 8-10 pins in it. My fan would only work on one setting also and I replaced this and it has worked on all speeds since.
Old Aug 31, 2017 | 12:53 PM
pwjackson42
This is an under the hood part, located somewhere near the blower motor...........It has been a good while since I replaced mine.
Old Aug 31, 2017 | 12:59 PM
pwjackson42
Advance Auto Parts #RU1013
Old Aug 31, 2017 | 02:06 PM
mudrat025's Avatar
mudrat025
ok.thanks guys.decided to install the motor however there is nothing coming out of the vents.does the resistor also control this??
Old Aug 31, 2017 | 02:13 PM
knottyrope's Avatar
knottyrope
resistor controls the slower speeds
Old Aug 31, 2017 | 02:32 PM
mudrat025's Avatar
mudrat025
geez....then what would stop airflow to the rig??its one thing after another lately with this thing
Old Aug 31, 2017 | 03:12 PM
Hussler's Avatar
Hussler
Is the new motor and squirrel cage spinning freely? The original symptom was certainly the resistor pack, sounds like it. It has a thermal fuse in it and lower speeds won't work. You cant replace the fuse, just get a new resistor package. Also fuse # 1 under dash protects this so take a look at that fuse.
Old Aug 31, 2017 | 03:23 PM
mudrat025's Avatar
mudrat025
everything spins freely,but only have high speed and cant seem to get air to come out of the vents like the gates are closed.
Old Aug 31, 2017 | 05:59 PM
z31freakify's Avatar
z31freakify
You didnt leave a rag in there did ya? Also check on the passenger side under dash the recirculating vent is in there and sometimes plastic bags get sucked in worth a check.
Old Aug 31, 2017 | 11:03 PM
madpogue's Avatar
madpogue
Is it blowing out anywhere? Floor outlets? Windshield outlets?
Old Aug 31, 2017 | 11:27 PM
mudrat025's Avatar
mudrat025
Nope. I didn't leave it Reagan there. Toward the park twice blower is running fine and there is no air coming from any outlets at all
Old Sep 1, 2017 | 06:59 AM
BuddyBarnes's Avatar
BuddyBarnes
I think I had this problem a long time ago. Pull the motor and check to see if it is turning the right way. On mine I reversed the wiring and all was well. Going by memory lol the motor can have reverse polarity. Worth a quick check.
Old Sep 1, 2017 | 07:41 AM
madpogue's Avatar
madpogue
Originally Posted by BuddyBarnes
On mine I reversed the wiring and...
That would suck....
Old Sep 1, 2017 | 08:57 AM
Jarrett Campbell's Avatar
Jarrett Campbell
Originally Posted by madpogue
That would suck....
Ha.........
