Question on Timing.
Old Nov 9, 2001 | 07:55 AM
Hartwood's Avatar
Hartwood
Question on Timing.
I have a 93 f-150 5.0 4x2 AOD. I have read how to check my base timing and it seems straight forward enough. The timing is supposed to be 10 degress BTDC, within +/- 2 degrees. What would be gained by advancing the base timing those 2 degrees? How much can I advance the timing before I have to run different gas? At what point am I simply increasing heat and not efficiency? Thanks,
regards,
Bryan
Old Nov 9, 2001 | 10:40 AM
Pastmaster's Avatar
Pastmaster
Question on Timing.
I also have a '93 F-150 with a 302. I advanced my timing to 4 degrees. Although it has some pinging, the off-the-line performance and mileage improved some.
I think you can advance the timing on our motors up to and including 6 degrees.
You have to unplug the spout connector, which is on the driver's fendor, next to the diagnosis ports. It has a little plug in it. The computer raises timing to about 17 degrees.
1993 F-150
1989 F-150 4x4
(http://briefcase.yahoo.com/toydestroyer1)
Old Nov 9, 2001 | 10:41 AM
bdonalds's Avatar
bdonalds
Question on Timing.
