Aerostar Ford Aerostar
Parking brake cable
Old Aug 30, 2017 | 09:07 PM
Mikeman's Avatar
Mikeman
Parking brake cable
I use my parking brake every time I park (assuming the cable isn't broken). The original cable lasted 17 years. The second cable (Raybestos) only lasted 2 years and 3 months. I got a replacement for "free" (still had to pay return shipping on the broken part) because of the lifetime guarantee but the second Raybestos cable only lasted 8 months.
For those of you who actually use their parking brake, what has been your experience? I recognize that there are a lot of people who never use their parking brake so I may just go snag one from the junkyard and see if I have better luck. Replacing the cable is somewhat of a PITA so it's not something I want to do every year or so.
Old Aug 31, 2017 | 04:28 AM
96_4wdr's Avatar
96_4wdr
Coat the cable with marine rated grease with calcium sulfonate in it before install.
Spray with anti corrosion spray yearly. They've started winter salting of our roads.
Old Aug 31, 2017 | 09:38 PM
Kruse's Avatar
Kruse
The quality of aftermarket replacement parts is, quite seriously, a race to the bottom. With that said, I would go to your friendly parts department of your local Ford dealer with the VIN of your van and request the part from the dealer.
Now before you panic, odds are the part is no longer available and the parts man will tell you that. Ask him nicely if he will give you the Ford part number. When he/she does, hit that number into a search engine and start looking for it. If it doesn't come up, ask Green Sales (not Green Ford) or another company that specializes in obsolete Ford parts and try to get the official Ford replacement part. You'll probably save money in the long run.
Old Sep 1, 2017 | 09:54 PM
Mikeman's Avatar
Mikeman
Corrosion or friction wasn't the problem with the first replacement cable. The doohicky (I have no idea what it's called) swaged onto the end of the cable pulled off. I haven't removed the second cable to know how it broke. I'll find out tomorrow if all goes well.
Old Sep 4, 2017 | 09:03 PM
Mikeman's Avatar
Mikeman
The second one failed the same way - the swaged end piece pulled off.
Old Sep 8, 2017 | 10:59 PM
Mikeman's Avatar
Mikeman
If anyone will be under the Aerostar this weekend, I was wondering if you could tell me if the OEM parking brake cable has nylon/plastic over the cable. The replacement cable has some sort of thin plastic layer covering the cable over nearly the entire length and there's a short section of black sheathing where the cable does the S-bend between the two frame sections toward the front.
I don't recall the OEM cable having the plastic layer over the cable (just the bare cable except where the sheathing is), but the last time I looked at an OEM cable was about 3 years ago.
Old Sep 12, 2017 | 11:25 AM
93nighthawk's Avatar
93nighthawk
E69Z 2A635-A x2 for the lines on the axle, Obsolete but multiple dealers show them.
E69Z-2A635-A | RearCounter.com | 18 found at 3 sellers
E69Z 2853-A would be the front cable.
Nothing is coming up on rear counter for that part #, ebay?
Old Sep 12, 2017 | 11:06 PM
Mikeman's Avatar
Mikeman
Thanks for the part numbers. I have no problem finding part numbers for my Toyota and Honda, but it seems like Ford goes out of their way to make it difficult. Is there a secret to finding them if you don't have the part in your hand?
Old Oct 23, 2017 | 03:07 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
NOS PARTS SOURCE in Olathe KS has 1 = 913-220-5746.
BOWEN SCARFF FORD in Kent WA has 1 = 253-852-1480.
FORD PARTS ONLY in Bayamon Puerto Rico has 1 = 787-786-9180.
Note: This and the rear cables ([2] E69Z-2A635-A with 10" brakes; 9" rear brakes use different cables) are listed for 1986/89. 1990/97 might be the same, might not be.
I could look 'em up, but the OP failed to list the year of his Aerostar. (sigh)
OP: Please, when asking questions, list ALL the pertinent info, we are not mind readers.
filthy6
Dec 19, 2017 11:52 AM
CNC
May 5, 2009 05:04 PM
PatsPOS
Jul 9, 2007 05:04 PM
rickm15752
Sep 30, 2006 10:55 PM
sullyda1
May 24, 2005 01:45 PM
