Gtp38r or spturbo 7x7 wheel
#46
I put a v clamp on there, it's just a spare one that would go where the x pipe connects. I suspect this is where I'll find my problem but I won't know until I test tonight after work. Either way I was planning to air test it to verify I have no leaks. I have some pressure testing soap from work that I can spray everything down with. It will for sure show any leaks.
#50
#51
on
Hopefully someone will have a tip we can ALL use
#53
#54
Ok I think there's some confusion, the up pipes and baby's butt are attached appear to be ok. It's leaking where the turbo attaches to the x pipe that goes to the intercooler pipes. I can't get the pipe done quite far enough to allow the grove to go into the turbo grove. I gave up for tonight it's 29 degrees outside and it's suppose to be 46 tomorrow which sounds much better to get frustrated in. Plus I have to change the v clamp at the up pipes any way tomorrow
#57
#60
on
In my earlier thread a lot of good tips were given: https://www.ford-trucks.com/forums/1...hat-sound.html
On my passenger side, I had trouble with the top clamp sliding down on the boot, losing its grip on the boot to spider connection.
I ended up putting an extra clamp in the middle to act as a spacer to hold the clamp in place, which solved my leak.
Bear in mind I have recently done a lot of work to seal up leaks- including the billet intakes and new SPX turbo wheel, so everything should be getting more pressure now than before.
A good tip for making the boots more flexible is putting them in hot water for about 10 mins.
I can also tell you that after running a little bit on the road, the boots are quite flexible compared to during cool installation.
Good luck!
Good luck!
