List of questions
Old 08-25-2017, 03:17 PM
Rustypanel's Avatar
Rustypanel
Rustypanel is offline
List of questions
I thought I should try to get all my questions on one thread.
1. Does anyone have a source for 1958 Panel tail light lenses? Need 2, whole assembly would be considered.
2. Is there a hydraulic lifter cam for a 223?
3. Is there a electronic module for a 223 distributor?
4. Best place to get a Holley 1904 rebuild kit?
I know there are more but the grey hair isn't letting the grey matter work.
Thanks, Rustypanel,
Medford, OR.
Old 08-25-2017, 06:10 PM
hiball3985's Avatar
hiball3985
hiball3985 is offline
1. No and harder to find then hens teeth
2. No
3. Check at Pertronix
4. Welcome to Mike's Carburetor Parts - Your Number 1 Carburetor Parts Store
Old 08-25-2017, 06:21 PM
dcmania's Avatar
dcmania
dcmania is offline
Check Desert Valley Auto Parts in Phoenix. Their inventory shows a 59 panel, but the pictures only show a front view. You should use the email request rather than call (experience) if the part is not on the truck, you won't get a response from them. All 1960 and older vehicles are in their Casa Grande lot. That's about 50 miles south of Phoenix.
Old 08-26-2017, 12:06 AM
Rustypanel's Avatar
Rustypanel
Thanks hiball and dc. I'll check the companies you mentioned.
Old 08-26-2017, 09:49 AM
willowbilly3's Avatar
willowbilly3
willowbilly3 is offline
I have watched those tail lights on ebay, reasonable price and end up without a bid, I'd put them on a search anyway.
Old 08-26-2017, 10:41 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1957/60 panels use the same tail lamps...can be very hard to find.
20 years ago if you wanted some, there were 100's available....NOS
Old 08-26-2017, 02:16 PM
oldbleu's Avatar
oldbleu
oldbleu is offline
The lenses you want can be found NOS on ebay.
Old 08-26-2017, 05:56 PM
Rustypanel's Avatar
Rustypanel
List of Questions
Thank you willowbilly3, NumberDummy and oldbleu. I'll let you know if I score the lenses.
Rustypanel
Old 08-27-2017, 08:05 AM
hiball3985's Avatar
hiball3985
Can you provide a link, I never see them..
Old 08-28-2017, 01:52 PM
oldbleu's Avatar
oldbleu
oldbleu is offline
Here are a few eBay item numbers:
#282594566084
#382077065465
#311564697988
#362957050915
#202018097009
Just do a search on each item number (minus the hashtag).
There are more......
Old 08-28-2017, 02:26 PM
Rustypanel's Avatar
Rustypanel
List of Questions
oldbleu,
Those eBay items are the license plate light and it lens. Mine is in good shape.
Thanks for the research.
Rustypanel
Old 08-28-2017, 02:35 PM
NumberDummy
1957/60 F100 Panel:
1) B7C-13450-B .. Tail Lamp Lens-Use with Door Mounted Rear Lamp and License Plate Lamp Combination / Obsolete
1) B8C-13450-A .. Right Tail Lamp Lens / Obsolete
1) B8C-13451-A .. Left Tail Lamp Lens / Obsolete
Parts catalog sez that the B8C lenses (tail lamps wrapped around the rear of the body) were used with turn signals, which were an option back then.
I would assume that without turn signals, only the door mounted combination lamp would have been present.
Old 08-28-2017, 02:39 PM
oldbleu's Avatar
oldbleu
oldbleu is offline
OK, I get it now.
Old 08-28-2017, 07:47 PM
hiball3985's Avatar
hiball3985
OK, I get it now.
Like I said, hens teeth
Old 08-29-2017, 04:47 PM
willowbilly3
I'd french some 59 caddy tail lights in there.
Quick Reply: List of questions
