Difference between 94and96 Front differentials
Old Aug 24, 2017 | 08:45 PM
garywolfer2's Avatar
garywolfer2
I used to have a 97 f-350 and now I have a 94 Prepowerstroke IDI I thought
they both had Dana 60 front differentials.What is the difference?I was told the 94 was stronger.
Old Aug 25, 2017 | 08:11 AM
A48WillyzGuy's Avatar
A48WillyzGuy
4x F350's will both have Dana 60's up front unless someone swapped it out.
Old Aug 25, 2017 | 08:55 AM
garywolfer2
The housings look different.The 94 looks more conventional than the 95 I compared to mine
Old Aug 25, 2017 | 09:15 AM
IDIoit's Avatar
IDIoit
pictures..
Old Aug 25, 2017 | 09:22 AM
A48WillyzGuy
You didn't say, but is your '94 an F250? It'll have a TTB front end which is in no way, shape, or form stronger than a solid Dana 60.
Old Aug 25, 2017 | 08:56 PM
garywolfer2
My 94 is an F-350
Old Aug 25, 2017 | 09:25 PM
garywolfer2
Sorry for the double photos
Old Aug 25, 2017 | 09:40 PM
IDIoit's Avatar
IDIoit
lmfao you double pictured us twice.
Old Aug 26, 2017 | 06:49 AM
tecgod13's Avatar
tecgod13
That looks like a ball joint Dana 60. The older ones had kingpins, I can't remember when they changed to ball joints...
Old Aug 26, 2017 | 07:20 AM
tjc transport's Avatar
tjc transport
i ain't rite
91 and older is kingpins. 92 and newer is ball joints.
Old Aug 26, 2017 | 10:49 AM
garywolfer2
This is similar to the front differential I saw on the 95 f-350 I was comparing my 94 f-350 to is this a Dana 50 and did they also come stock in 95 and
newer f-350's or did it likelycome out of a f-250?
Also I read in another thread someone had 411 rearendgears and 377 front end gears wouldn't that tear up one or the other? I know they cannot be the same ratio bu t I thought front ratio on a 411 would have a 410 in the front?
Old Aug 26, 2017 | 12:34 PM
madpogue's Avatar
madpogue
That last pic is of a TTB, so either the truck is not an F350, or the axle's been downgraded.
Old Aug 26, 2017 | 02:32 PM
tjc transport
i ain't rite
4.11 and 3.73 gears would destroy a transfer case.
gear ratios have to be the same or 1-2 numbers off.
4.11 rear would have either 4.11, 4.10, or 4.09 front.
Old Aug 26, 2017 | 04:18 PM
garywolfer2
That is What I thought Tom.Thanks
swampthing
Ford Truck Parts for Sale
Sep 28, 2015 03:49 PM
stainlessstroker95
64
Mar 1, 2012 12:40 PM
Talyn
May 30, 2010 09:08 AM
bcarless
Nov 29, 2009 02:57 PM
