The 390 flywheel which is so often said to be the one to use when dropping a 429 into a '73-'79 era truck is also compatible with many other models of Ford or Mercury isn't it?
The only difference between the 352/360 & 390 flywheel is the size of the clutch. Either can be used.
C5AZ-6375-K .. 352/360 Flywheel-Use with 11" Clutch - (6) 5/16" -18 pressure plate attaching holes on a 12 3/8" bolt circle / Obsolete
1965/67 Ford 352 Passenger Cars & F100/350 352; 1968/76 F100/350 360.
------------------------------------------------------------------------------------- C5AZ-6375-L .. 390 Flywheel-Use with 11 1/2" Clutch - (6) 5/16" -18 pressure plate attaching holes on a 12 7/8" bolt circle / Obsolete
