Sponsored by: Real Truck
Need Help with Knocking 6.8 V10
Old Aug 22, 2017 | 07:39 PM
Trickysleeves's Avatar
Trickysleeves
I need help diagnosing a knock in my engine. The previous owner said he put it in the shop to have the transmission rebuilt and after it came out something popped and it started knocking.
I'm pretty sure it isn't in the transmission but i have no idea what it is or if it can be fixed or if the motor is done.
Here is my best attempt at describing what it's doing. The truck has 126k on it and it starts fine and usually the knocking starts right away but sometimes goes away at idle. I can move it around but any good blip of the throttle makes it die. If you ease in to the throttle it will stay running. The exhaust was cut for some reason so that is the noise you hear ticking in the videos. Oil pressure is fine. The oil looks clean as far as the dipstick goes.
This was a cold start so it stays rev'd for a bit in the first video. I gave it some throttle a few times to hear the knock and see if it would die. It didn't die on it's own in the first video with a few revs but it did die on it's own in the second video. The knock is not consistent. It seems to come and go. Sometimes you can rev it with no knock and other times like in the video it will get louder with revs.
So what do you think, is she done? I appreciate the help. Thanks in advance.
Old Aug 22, 2017 | 10:12 PM
Sam I Am's Avatar
Sam I Am
Sounds kind of like something external to the engine.
Try taking off the belt and starting it for a moment to see if it still does the noise.
While the belt is off wiggle all the pulleys.
Old Aug 22, 2017 | 10:33 PM
Trickysleeves
I didn't think of that. Thanks, going to try it tomorrow.
Old Aug 22, 2017 | 10:40 PM
billybobofkf's Avatar
billybobofkf
I agree with SamIAm, that doesn't sound like anything internal. Other thoughts, check the exhaust and heat shields. Also, what transmission work? If the transmission came out, pull the front cover and make sure the torque converter got bolted up tight to the flywheel. Check the flywheel for cracks. A cracked flywheel can make some crazy sounds.
Old Aug 23, 2017 | 04:41 AM
redford's Avatar
redford
FTE Leadership Emeritus
My first thought was also the torque converter bolts.
Old Aug 23, 2017 | 06:51 AM
speakerfritz's Avatar
speakerfritz
Im going to say piston
what do the cylinder pressures look like
Old Aug 23, 2017 | 08:44 AM
Trickysleeves
The transmission was rebuilt. According to the PO they had hell getting the transmission back in. Our initial that was a cracked flywheel but we checked the flywheel by bumping it over and everything appeared fine.
Old Aug 23, 2017 | 09:10 AM
speakerfritz
The reason I don't think it's a torque converter is it would not make that noise at idle...would do it when the torque converter is locked
Old Mar 21, 2024 | 05:00 PM
JustinLB's Avatar
JustinLB
What ended up being the problem?
abumchuck
Modular V10 (6.8l)
Aug 29, 2013 08:24 PM
AbandonedBronco
1978 - 1996 Big Bronco
Jan 12, 2011 09:47 AM
Tony G
Modular V10 (6.8l)
Jul 30, 2008 10:31 PM
mightymoose2
Modular V10 (6.8l)
Sep 18, 2006 10:41 AM
mdpopo59
Modular V10 (6.8l)
30
Mar 18, 2006 02:30 PM
